Any ideas...
Old Aug 4, 2007 | 06:53 PM
  #46
99SevenPoint3's Avatar
99SevenPoint3
well i rebuilt the trubo and everything snaped back into place ..actually felt really easy ...
Old Aug 4, 2007 | 07:02 PM
  #47
ron's power stroke's Avatar
ron's power stroke
is the oil coming out of the exhaust??? or is it from in the valley?thats a lot of oil...you had to of lost some on the dip stick?? right?? how much?
Old Aug 4, 2007 | 07:07 PM
  #48
99SevenPoint3
yeah its coming from the exhaust valley is clean ... and i was kinda tired and frustraded so i didnt really check how low i was ... maybe tommorow
Old Aug 4, 2007 | 07:11 PM
  #49
ron's power stroke
damn that sucks..im sorry too hear that..wish i could help you out more..maybe i asked enouph questions that some will chime in later with more help..
Old Aug 4, 2007 | 07:21 PM
  #50
99SevenPoint3
ooh yeah hopefully someone will come to my aid but i am greatful i have this site to help me out along my troubled ways and with the questions i have Only thing i hate is not driving the truck ...but again i hadnt had problems in the past with any of these things so i guess its about time to have some problems and hopefully when its fixed i wont be having anymore major problems for another long time...
Old Aug 4, 2007 | 07:34 PM
  #51
medhvac's Avatar
medhvac
could that be blow by? pull your hose of your turbo and look in there is the turbo got a lot of oil on it? just a thought!
Old Aug 4, 2007 | 08:17 PM
  #52
Kwikkordead's Avatar
Kwikkordead
Should be easy to find a leak of that magnitude.
I guess I was wrong about the injectors. Too bad as it would have been an easy fix.
Old Aug 4, 2007 | 09:58 PM
  #53
99SevenPoint3
well it never hurts to try ... as for leaks i figured if its going to come out the valley it would be soaked but its clean ... no sign of any leakage just the oil coming out of the exhaust ... jeremy aka jtharvey had asked me if i had seen any oil in my up pipes when i removed the tubo but the up-pips were clean just your normal soot but none built up ... the only thing with oil was the exhaust part of the turbo thats why i had thought it might have been a seal in the tubo ... but when i took the tubo apart and recieved the new parts the old parts did not seem to be damaged in any way but some how oil was in the exhaust part of my turbo and now i see oil coming out the exhaust were is it coming from ??? if u guys got a minute you can check out my white smoke topic and can see the pictures of my turbo insides ... as for tommorow i may take a video of the truck idling and without the oil cap so u can see what i got going here ...
Old Aug 6, 2007 | 11:02 AM
  #54
99SevenPoint3
ok heres another video for u guys to take a look just the oil cap on and off ...some of u guys mentions blow bye so since im not exactly sure what that means u guys can take a look for yourselfs..
http://s70.photobucket.com/albums/i9...t=MOV_RUN3.flv
http://s70.photobucket.com/albums/i9...t=MOV_RUN1.flv
http://s70.photobucket.com/albums/i9...t=MOV_RUN2.flv
Old Aug 6, 2007 | 07:44 PM
  #55
99SevenPoint3
So come on guys any more ideas for me ...
Old Aug 6, 2007 | 08:04 PM
  #56
medhvac's Avatar
medhvac
Check your CCV mod--- itsp prolly plugged or pinched not allowing Crank gasses to leave and there leaving through the turbo instead.
Old Aug 6, 2007 | 08:05 PM
  #57
medhvac's Avatar
medhvac
just a thought
Old Aug 6, 2007 | 08:20 PM
  #58
ron's power stroke
was this oil and smoke the reason for the turbo rebuild?? or did this happan after the rebuild??
Old Aug 6, 2007 | 11:25 PM
  #59
jtharvey's Avatar
jtharvey
The oil and smoke was the reason for the turbo rebuild. I'm thinking there's still something not right with the turbo though. I'm thinking this because I can't see why else the uppipes don't have an oily residue in them, but the turbine housing and downpipe do? To me, that almost pinpoints the problem with the turbo. I know it was just rebuilt, but perhaps there's a problem with the turbo still, like in the center section not allowing the ring seal to function properly. I with you could get a different turbo to try, one that's known to not have any issues, and bolt it on to see if there's any difference.
Old Aug 7, 2007 | 06:59 AM
  #60
Kwikkordead
What Jeremy said.
