Fue L Pump ?????
Old Aug 3, 2007 | 02:45 PM
yh731801's Avatar
yh731801
Fue L Pump ?????
1988 F-150, 4.9 It won't run unless I use the jimper on the test plug, I'm now driving it with the jumper.
Old Aug 3, 2007 | 03:59 PM
andym's Avatar
andym
Fuel pump relay.
Old Aug 3, 2007 | 04:03 PM
yh731801's Avatar
yh731801
relay works when I jump the fuel pump test connector to ground( I hear it click)
Old Aug 3, 2007 | 05:50 PM
subford's Avatar
subford
You have an open in the wiring from the relay to the EEC Computer, the Computer Plug (pin) or a problem with the Computer.
Old Aug 3, 2007 | 06:36 PM
ameritaz3038's Avatar
ameritaz3038
curious where this test plug is as it may help me trouble shoot my front pump on a (info below) , if i understand right the relay is for both front and back.
Old Aug 3, 2007 | 07:08 PM
subford's Avatar
subford
Your 1996 does not have this test plug.
Yes the relay is for both the front and rear pumps.
Old Aug 4, 2007 | 07:58 AM
yh731801's Avatar
yh731801
cold iy be a weak fuel pump ? I can't hear the high pressure pump -I have to lay my hand on it to know it is running
Old Aug 4, 2007 | 08:15 AM
subford's Avatar
subford
No, grounding pin #6 of the test connector and it runs says that the wiring after and before the relay are OK along with the pumps.
Not saying you might not have a bad pump but you need to get the fuel pump relay working right first.
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
