tires size does it matter
Old Jul 27, 2007 | 03:58 PM
Shelbyf150's Avatar
Shelbyf150
Question tires size does it matter
I have a 1992 f150 inline six fwd reg cab now my front seems like its has ligth duty springs and havey duty leafs in the back.I have a brother inlaw that has
an 89 f250 inline 6 fwd reg cab with heavy duty springs and leafs and he can put 35 12.5 on his, but they rub alittle.My question here is will i be able to put 33 12.5 on my truck or will they rub like the f 250 35s?
or if theres a post already can some one point me in the rigth direction.thank you for you time.
Old Jul 27, 2007 | 04:10 PM
Dean88's Avatar
Dean88
Are you just wanting to put the 33's in the back? If you are, they will easily fit in the back, being I have 35's in the back. But you might be able to squeeze the 33's in the front if you put a spacer in and don't crank the wheel all the way, and don't do crazy wheelin.
Old Jul 27, 2007 | 04:22 PM
Shelbyf150's Avatar
Shelbyf150
yeah i want to put all four 33s i got some rims for them i think there the same offset inside as the stock rims.but the way its sound it migth not be a good idea with out a lift rigth ?.
Old Jul 27, 2007 | 06:08 PM
lostin90s's Avatar
lostin90s
It will be really tight . Like turn wrong and bend bumper tight. Get a lift kit then the 33"
Stick with 31" and mayby 32" . You truck sit lower than a 250 If it rubs on his it will hit hard on yours.
Old Aug 4, 2007 | 08:49 AM
Shelbyf150's Avatar
Shelbyf150
hay thanks guys. for the info.i really appericate it.
