BioDiesel
Old Sep 9, 2007 | 09:30 PM
  #31
aklim's Avatar
aklim
Originally Posted by RedDragon
I run B99 whenever possible. It is currently a few cents more than dino, but not too long ago it was a few cents less. As for performance, MPG for me is about .8 MPG less than dino, but engine runs great on Bio so the MPG is not a big enough difference for me to switch back.
So, other than the sound, it loses power and mileage. Not sure how that is "better" in my book. I broke even mileage wise on B20 and B40, I would lose at least 1 mpg and it only gets worse going up. IIRC, I lost 1.5 at B60. I splash mix it so I get the same fuel every time. On my diesel car, I would get 650 miles on a tank and I fill it till you can fill no more literally. Switching to fuel from another shop and I can't even break 600 miles. This way I keep the fuel as consistant as possible and calculate in the B100 to put in the tank.
Old Sep 9, 2007 | 09:35 PM
  #32
F350-6's Avatar
F350-6
Originally Posted by aklim
Doesn't that tell you that lubricity is not an issue? The sound of the engine comes from the ignition and not the lubricity.
I guess it does. I never put that much thought into it. With everything I've read about reduced lubricity with LSD & now ULSD. I grew up in a time when you could just about tune an engine by sound, so a smoother running engine goes a long way for me.
Old Sep 9, 2007 | 09:41 PM
  #33
aklim's Avatar
aklim
ULSD has lower lubricity. However, that is if you just take ULSD out of the refinery. At the terminal level, they will add the lubricity agents to make it meet the same ATSM standard of LSD. As such, I am not worried about ULSD and lubricity. My only worry about ULSD would be that ULSD causes some seal shrinkage. However, with the newer seals, that should not be an issue either.
Perhaps so. However, when you change the amount of fuel or timing, aren't you also changing the combustion charistics? IOW, if you advance the timing, what are you doing? Changing when the flame starts with respect to the piston position. What happens if you advance the timing too much? You get a different sound too.
Old Sep 9, 2007 | 09:47 PM
  #34
F350-6's Avatar
F350-6
I thought I read that the EPA set the lubricity standard for lubricity lower than the injector manufacturer's wanted, which is why I've been concerned. Of course I also have the leftover concern from the switch to LSD.
By the way, what does "IOW" stand for?
Old Sep 9, 2007 | 09:55 PM
  #35
Gradymeister's Avatar
Gradymeister
In Other Words
Old Sep 9, 2007 | 09:57 PM
  #36
aklim's Avatar
aklim
It was lower that what the manufacturers wanted but IIRC, it was equivalent to LSD
In Other Words
Old Sep 9, 2007 | 10:00 PM
  #37
RedDragon's Avatar
RedDragon
So, other than the sound, it loses power and mileage. Not sure how that is "better" in my book. ....
I have not noticed a power loss and mileage loss is little and acceptable for me. However, I am not driving long hauls anymore and just around town doesn't really matter. I prefer the cleaner burning bio which is more eco friendly and supports farmers rather than oil sheiks.
Old Sep 9, 2007 | 10:04 PM
  #38
aklim's Avatar
aklim
If you lose power, you probably would lose mileage and vice versa. AFAIK, it is all related to the lower energy content.
Most of our oil doesn't come from sheiks. IIRC, only 20% would. In any case, almost anything we touch is going to be "sheik oil tainted"
Old Sep 9, 2007 | 10:07 PM
  #39
elvia's Avatar
elvia
I don't know the power loss with bio, but with wvo (waste vegetable oil) there is about a 3 to 5% loss.
Old Sep 9, 2007 | 10:08 PM
  #40
aklim's Avatar
aklim
If they are even admitting to a loss, it must be more than an insignificant one. I thought I read about 1-5% depending on the technology used.
Old Sep 9, 2007 | 10:13 PM
  #41
RedDragon's Avatar
RedDragon
.... Most of our oil doesn't come from sheiks. IIRC, only 20% would. In any case, almost anything we touch is going to be "sheik oil tainted"
That's true! I hate the money grubbing oil companies. I just wish it was possible/feasible for us all to grow and make our own fuel and take back some of that money lining their pockets.
Old Sep 9, 2007 | 10:25 PM
  #42
aklim's Avatar
aklim
Well, firstly, if you are a stockholder in any company, you would expect it to make as much as possible or you drop the stock. Secondly, I don't think that what they make is that much. Sure, 10 bil is a lot. So is the 100 bil they spent to make the 10 bil. I hope my business makes more than that, percentage wise. Thirdly, there are so many other products that oil makes, it would require you to live off the land with no modern conveniences to avoid oil.
Old Sep 10, 2007 | 02:40 PM
  #43
Izzy351's Avatar
Izzy351
FWIW, I put some B99.9 (yes, that's what they called it!!) in my tank a couple weeks ago, and I noticed an instant quieting down of the injectors. I had D2 in there with 12oz. of DK, but as soon as the BD hit, it got quieter. I happened to have another 7.3 F250 owner in the cab and I poked my head in while it was pumping and said "Did you hear that??" He said, "It got quieter, didn't it?" I said "I was pretty sure I hear a difference, but I was wondering if you heard it..."
Quieter injectors means less wear. Less wear means they last longer. So to answer you question about it affecting your pocket book, I'd say a set of injectors is worth a few pennies more per gallon -- hopefully less like it used to be for B100 (99.9).
Old Sep 10, 2007 | 03:14 PM
  #44
aklim's Avatar
aklim
How did you determine that the injectors quietened down? Were you listening to the engine or did you have somethign on the injector itself? I heard a slight noise reduction driving with B20. Actually, I heard more noise reduction after the DI Regulated Return than the B50 I tried.
How much longer will it last? IOW, without the quietening down, what is the lifespan vs quietening it down? If the difference is between 350K and 300K, it might not make a difference.
Old Sep 10, 2007 | 04:46 PM
  #45
Fat Diesel's Avatar
Fat Diesel
FYI: Hose that you install with a 30R7 rating may not be bio compatible. I had a pin hole leak on a piece of Non-Ford 30R7 hose that I had put on my fuel system. I'm not sure if 30R9 will work, but I know teflon will. I am going to install braided stainless over teflon for my entire system within the next few weeks.
My mileage seems the same on B99. I get 13.4 going to work and back, and 13.7 towing the dune buggy and trailer up the grade to Reno. Speed seems to be the big factor.
My power seems the same on B99.
