Offroad & 4x4
when will I learn
Old Aug 1, 2007 | 09:55 PM
captain p4's Avatar
captain p4
when will I learn
that i shouldn't use the impact on small bolts.
So I broke both bolts that hold that brake calipers on, first the passenger side with the impact, then the driver's side with a wrench. I managed to get the passenger side bolt out with an extractor set, so that side is good, but I can't get the driver's side out. Will the clip be enough to hold the brake caliper on or should I swap in a new bracket?
Dubz has a spare d44 laying around, so I'll be able to get a new bracket if I need it, but just wanted to make sure before I did all that work.
The more I type the dumber this question is sounding, I think I'm going to be told to get the new bracket, am I right?
Old Aug 1, 2007 | 10:00 PM
clong's Avatar
clong
You are correct. Replace the bracket and be safe.
Old Aug 1, 2007 | 10:03 PM
dirtjumper01's Avatar
dirtjumper01
hey! I did the same thing to my dads old 79 F-150 2 wheel drive. It was really loud in the garage, I wasn't thinking straight and then the bolt head just fell off.
Old Aug 1, 2007 | 10:04 PM
monsterbaby's Avatar
monsterbaby
I have drilled and tapped that bolt out to the next larger size (5/16ths as I recall) adn used a new bolt with out any problems
79-400-POWER's Avatar
79-400-POWER
lol
I did the same thing with a wrench on my old truck. I just left the clip on it and never had a prblam wiht it. But if you can, go ahead and swap in a new bracket.
Old Aug 2, 2007 | 07:44 AM
teds74ford's Avatar
teds74ford
I was thinking like monsterbaby. The worst that will happen is that you waste some time if you don't like it once you're done
Old Aug 2, 2007 | 10:21 AM
armikk's Avatar
armikk
Another option is just drilling it all the way through and putting a longer bolt in with a lock nut on the backside. It isn't as convenient when taking it off / putting back on, but works fine...
Old Aug 2, 2007 | 11:19 AM
captain p4's Avatar
captain p4
Yeah, I figure I'll just drill right through and try to fit a nut on the back, then if it doesn't fit I'll tap it. Then if after all that its not working I'll go scrounge the parts from my buddy.
I was just tired last night and didn't feel like doing any more work, lol.
Old Aug 2, 2007 | 03:58 PM
monsterbaby
like I said just drill it and tap it to next bigger bolt size and don't mess with the nut on the back side this works real well have done it on several including the race truck and never had one give me any problems.
zerocoolsob
Mar 26, 2014 06:22 AM
tjc transport
General Automotive Discussion
15
Oct 16, 2012 04:29 PM
tjc transport
Offroad & 4x4
21
Oct 14, 2012 05:32 PM
CobraGT40
Mar 19, 2010 07:24 PM
jackstraw
Jan 13, 2009 09:58 PM
