Autometer Guage Question!
Old Jan 22, 2017 | 11:59 AM
seagiant's Avatar
seagiant
Hi,
I bought a set of Auto meter Guages.
They have regular bulbs (not LED's)
I was looking for the best place to wire in the dimmer lights.
Some say the OEM dimmer light switch wire...
Others say run a switched 12V wire with an aftermarket dimmer unit???
Soldered in diodes?
Wondering how you guys hook these up??? Thanks!
Old Jan 22, 2017 | 12:11 PM
Fastback460's Avatar
Fastback460
I used an Add-A-Fuse and hooked into my instrument cluster fuse inside the fuse panel. It works with the factory dimmer.
Old Jan 22, 2017 | 12:19 PM
seagiant's Avatar
seagiant
Hi,
Thanks, THEN.....I assume it is a fuse in the OEM fuse box FOR the dimmer OEM instrument cluster???
Old Jan 22, 2017 | 12:22 PM
seagiant's Avatar
seagiant
Hi,
That would be fuse #4 in this schematic?
Or #10?
Old Jan 22, 2017 | 12:27 PM
78 PEB's Avatar
78 PEB
I would say #10.....drag out a test light and see if it dims.....
Old Jan 22, 2017 | 12:34 PM
seagiant's Avatar
seagiant
Hi,
Thanks! I just happen to have one of those!!!
I assume I would then buy the same amp, add a fuse?
Old Jan 22, 2017 | 03:08 PM
Fastback460
I used the #10 fuse slot.
And I just got an Add-A-Fuse that holds the same size fuses that these trucks use, (not those fuses that are like half the size). That way I don't need to have 2 buy two different size fuses all the time.
Old Jan 22, 2017 | 05:39 PM
seagiant's Avatar
seagiant
Hi,
Thanks this seems to be the way to go.
Are you guys having to use an independent pot switch or soldered diodes to get the right level of brightness on the gauges?????
73stang
Oct 21, 2016 09:21 AM
frenchf250
Oct 25, 2006 04:14 PM
buffaloearl
1997 - 2003 F150
Jul 12, 2005 08:28 PM
butchhutch
15
Jun 25, 2004 11:37 AM
sxewhodey
Bronco II
Jul 2, 2003 05:33 AM
