I had a band bust in a tire before and I could actually feel the tire out of round at VERY slot speed, i.e. 2mph on a very flat road. The tire also wears heavily at the spot where the band broke. To break a band in your big meats would take a serious event though.
Mark the tires and start rotating them all over the place. I would even try out a friends tires. My guess is that it is in the lift and driveline angles.
The lift has been on for as at least a year and a half. I did correct the driveline angle, its is as level as i can get it. It got better today, but it seams like when im turning the bouncing get worse, like long curves i can feel it in the floor the most now.
My truck does have a lift and i did get normal sway bar endlinks, could that be the problem? Also an adjustable trac bar like ed is talking about where would i find one?
Probably nothing to do with your wobble but does have to do with the sway bar installation.
Make sure your drop links are adjusted so that they are pointing straight down. Also, i find that it is good to secure one each (two total for install) split links/rings on the inside of each of the two bushing (center of truck). Here is a good link with pics https://www.928gt.com/frontswaybarinstall.htm
could b ur shocks r bad did u ck ur ball joints and wheel hub assembly and r u familar with procedur
ok so may b ur shocks did u ck ur balljoints also look at ur wheel hub assembly and are u familiarized with the procedures on how to ck everything correctly .well either one requires that sthe wheel position ur ckin is in a relaxed state or droped with no preasure on them ..
i also have a 99 f250 with 37s on 20rims never had a single vibration lifted it with 5" on front drove it nothing did 2" on resr now it feels like front wheel is gonna fly off ittermitely may b a bumb or just 38 45 mph comes and goes 65 70 and up nothing id say ck ur carrier bearing and possinly drop it a bit more and ujoints n front axle and if u never had a issue b4 with ur rims and tires chances r u still dont less u curbed em or something idc if u have 44s on ur trk if it never had a issue chances r they r still fine iv mounted several different tires on my rims from 35s to 37s never balanced one time and never had a vibration ever far as ur sway bar goes if it hooked up its workin less its bowed out and rubing ur leaf springs or ur shakles r bent
also i just wanna throw out there ck n2 ur axle wrap and if u need a set of ladder bars and possible thats y u have a come and go vibration as it's changing angles as it wraps. just something to ck as well
U mgt ck th dt on ths thrd........It is only 14 years old!
