ignition system problem
Old Aug 26, 2007 | 10:53 PM
emiltech's Avatar
emiltech
which fuseable link?
Originally Posted by Virto
Check your fusible links. If you have a loose one it could expand in the heat and lose contact and when it cools make a better connection. Had a similar situation in my truck.
EDIT: I would lose all electrics in the whole truck. No lights, no radio, no voltmeter. I thought battery too, but I had a new one to swap and still got nothing.
is there a fuseable link for the ignition.....no codes are being generated....coil has all the correct signals etc. but no spark....
Old Aug 26, 2007 | 11:15 PM
KC92F150's Avatar
KC92F150
I think I would check the ignition switch. When they go bad a lot of strange things happen. Good Luck.
Kevin
jitterymonkey
Nov 12, 2013 08:07 PM
JoeKramer
16
May 7, 2011 03:10 PM
lonewulf76
Escape & Escape Hybrid
Sep 8, 2009 10:41 AM
saltydog73
Dec 31, 2006 12:42 PM
dan1101
Mar 30, 2006 11:50 PM
