Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Starter problems 2003 escape
Old Sep 6, 2009 | 12:46 PM
lonewulf76's Avatar
lonewulf76
Hello everyone,
I hope someone can help me. Ok, my starter was going out so i replaced it and when i tried to turn it on nothing, nothing at all the battery is a full charge (12.6v). So when i started checking everything i found that there is no power going to the ignition wire for the starter solenoid (the smaller wire) and i believe there should be. Also check relay's and fuses all good and also moved some around to make sure. Tested starter at kragen and test good, I don't know what else to do, start checking wires. If anyone knows what else should i check i would be in your thanks.
Old Sep 6, 2009 | 05:05 PM
87 XLT's Avatar
87 XLT
Does it have a transmission or is it a slugomatic? If it's a slugomatic, it sounds like a problem with the neutral safety switch
Does it crank when you shift to neutral?
Old Sep 6, 2009 | 05:31 PM
lonewulf76's Avatar
lonewulf76
no it does not crank at all in any gear. its an automatic i do not know if it is a slugomatic how do i tell? where is the neutral safety switch at and how can i check to see if that is the problem. Thanks for all the help.
Old Sep 6, 2009 | 06:35 PM
87 XLT's Avatar
87 XLT
I have a battery load tester that is real handy at times like this. 12.6 volts is a good number, but it still might fail a load test.
If the connections at the battery are clean & tight one simple thing you can try is to add a jumper wire to the cables.
When my 87 Ranger would'nt crank & I added a jumper from the negative battery post to the engine block & it fired right up, I knew that cable was bad.
To be sure you dont jump incorrectly take a quick look at your starter circuit wiring diagram.
OR
Plan B get a jump from another car & see what it does.
BTW, since it wont crank in neutral either, the neutral switch is probably not the problem
A slugomatic IS an automatic
Old Sep 7, 2009 | 07:55 PM
lonewulf76's Avatar
lonewulf76
it took a few days but i figured it out, i had a bad wire from ignition switch to the interior fuse panel connector 270d, changed wire all works great thanks all for great ideas.
Old Sep 8, 2009 | 10:41 AM
87 XLT's Avatar
87 XLT
And thanks for the update, glad you found the problem.
fordatic
Sep 23, 2016 01:28 PM
InfidelReaper
Apr 2, 2013 02:54 AM
CD1993
Aug 27, 2012 11:11 AM
BRay09
31
Jun 21, 2011 12:14 PM
Big Chill
Mar 1, 2011 06:49 AM
