I have a 1991 F250 7.3L Diesel that has decided to stop starting... hopefully, someone here can make some suggestions. When I try to start the truck, the solenoid clicks once and then everything electrical dies. I had the starter bench tested at AutoZone and they say that it is fine, as are the batteries (tested also). I connect the two battery wires to the solenoid and leave it hanging rather than connecting it the fly wheel... one solenoid click and nothing. I replaced the stupid "Ford" solenoid on the fender of the truck (I don't know why Ford insists on two solenoids but that can be for another post) - one click solenoid and nothing. I took a jumper cable and went between the + post of one battery and the corresponding post on the starter's solenoid... this time I get one solenoid click, a few (5-6) cranks and then nothing. The wire on the jumper cable heats up and starts melting the plastic sheath (I think if it was heavy enough gauge that jumping the battery to the solenoid would work). My dad tells me to check all the cable connections (+/- wires)... I checked and cleaned all the (+) connections with a wire wheel on a grinder or sandpaper so they are all clean (bare metal). I didn't check or clean the engine or frame grounds because I think that if I had a ground issue, my battery to starter solenoid jumping would produce the same results as without the jumping... I did nothing to the ground when I run the jumper cable. My next option is to replace the battery cables... I call Ford and they want $300 for the cables (are you f-ing kidding me? I understand copper is expensive but how does the dealership justify that price?), AutoZone wants $110... note about the cable; the (-) cables are pretty standard, the (+) cable is connected to the left-hand battery, runs to the right-hand battery, and then splits. From here, one wire (16 gauge) goes to the "Ford" fender solenoid and then goes to the starter solenoid; the other wire (4 gauge) goes to another post on the starter solenoid. I am going to wait until Tuesday to see how much a battery shop can make the cable for me, but before I do that, am I missing something that I can check or change? Could my jumper between the (+) on one terminal to the starter solenoid really work if I had a ground issue? Again, when I do this, all the battery wires are connected as they would be from the dealership. I generally drive the truck to tow my boat only; this all happened when I took it for a drive (ran about 20 min) and then turned it off outside of a store... hasn't started since.
I would definetly check the ground connections, as they can exhibit these symptoms. I would also start to suspect the starter motor itself, as I am not very confident that the bench testers work very well when there is no load on the starter, and a diesel has a lot of starter load. I wouldnt spend the money on having a shop do you some cables, I would make my own out of 2 or 4 gauge welding cable and nice solder on ends for the cables. I little bit more exspensive than normal battery cable, but they are by far worth it. I had a similar problem with my bronco which has dual batteries and replaced the cables and my motor turns over like nothing else.
