brake problems
Old Jul 29, 2007 | 09:10 PM
thefuzz472's Avatar
thefuzz472
Cool brake problems
I have a 1991 f-250 with 7.3. The brake pedal is hard. I put a new vacum pump,new booster and a new master cylinder bled the brakes and nothing helped. It feels like I have no power brakes the pedal is hard. Have new rotors on the front and new pads. Anything else I can check?
Old Jul 29, 2007 | 09:38 PM
Franklin2's Avatar
Franklin2
Pull the hose off the booster and see if you have vacuum.
Old Jul 29, 2007 | 09:41 PM
thefuzz472's Avatar
thefuzz472
yes it has vacum i can put my thumb over the hose and it sucks hard
Old Jul 29, 2007 | 10:52 PM
David85's Avatar
David85
OK, now start it up, and run it for a minuite or so, then shut it down, and wait for another minuite. Now pull the booster hose, there should be an audible hiss as the vacuum is breached, if not, the booster could be leaking.
Another thing to try is to compare how the brakes feel with or without the booster hooked up, a test in the drive way is all you need here (ie, don't actually drive it).
Old Jul 30, 2007 | 09:22 AM
bgnnmike's Avatar
bgnnmike
Been there, done that, I have a 1992 F 350,7.3, crew cab, changed Master cyl (1 -1/8"), vac pump, RABS sensor,(rear anti-lock Sensor part near floor and firewall) front calipers and brake rubber hoses, turned rotors, new pads, rear brake cyls, new shoes and kits, and most of the steel brake lines and have bleed the crap out of the system many times. I STILL don't have what I consider decent brakes- I can stand on the pedal with 2 feet, on a gravel road and can't lock any thing up.I have not changed the booster yet.I also get the brake light on sometimes while running up the hwy. ???? I was told by a buddy to run the master cyl. from a F450 a 1-1/4 bore would help! hope you get some answers Mike
Old Jul 30, 2007 | 10:59 AM
lartross's Avatar
lartross
I did the same thing Dave did...installed a hydroboost system. My brakes were ok, but, I wanted the best I could get,within reason, so...
Old Jul 30, 2007 | 01:50 PM
thefuzz472's Avatar
thefuzz472
I put a vacuuum gage on the line going to the booster and it read 22 so i know i am getting plenty of vacuum.
Old Jul 30, 2007 | 03:23 PM
Oregon-Mike's Avatar
Oregon-Mike
fuzz,
With the gauge still connected, press the brake pedal down fully a couple or three times. Check to see how long it takes to rebuild the vacuum. Mine had decent vacuum but took minutes to rebuild after using the brakes. Had to stand on them to get the beast to stop if I was in any kind of in-town traffic. New pump & all's been well for several months on my pickup.
Mike
Old Jul 30, 2007 | 04:08 PM
PLC7.3's Avatar
PLC7.3
Google.... cdnsarguy Brake vacuum test
cr506
18
Apr 8, 2010 08:16 PM
bansheeman95
Mar 20, 2010 03:10 PM
rick offey
General Diesel Discussion
Jan 26, 2009 02:28 PM
hunter1897
1966 - 1977 Early Broncos
Jul 1, 2007 08:49 PM
tonysquirrel
Jul 25, 2004 04:59 PM
