General Diesel Discussion
brake problems
Old Jan 24, 2009 | 08:11 PM
rick offey's Avatar
rick offey
Unhappy brake problems
i have replaced booster/mastercly./abs valve /pump wheel cly/lines/ all parts are new problem pedal hard when not running when running pedal goes to floor pump up and pedal gets hard then goes to floor bleed master cly/weel cly.and lines /abs valve/ect cannot get brakes towork please help
Old Jan 24, 2009 | 08:25 PM
senix's Avatar
senix
still air in the lines somewhere. Have you checked all the brake lines? When you bleed the brakes, recheck the bleeder valve to ensure it is closed before letting off the brake.
Old Jan 26, 2009 | 02:28 PM
Lazy K's Avatar
Lazy K
Exactly right. What he says and are you bleeding in the correct sequence? And what is it?
colokerrie
Dec 23, 2012 07:57 AM
argusman
Mar 31, 2008 11:58 AM
rcm800
15
Feb 3, 2005 04:02 PM
david nip
Jul 28, 2004 08:31 PM
1990350
May 3, 2004 09:18 PM
