302 swap
Old Nov 7, 2000 | 01:10 PM
pinegreen's Avatar
pinegreen
302 swap
74 302 from ford 150 going into 1980 ford ranger 150. I need an oil pan fro a 302 that has dipstick in the panand the pan must have the "oil well" in the rear/closest to transmission to even begin to make this backyard project work...in the mean time both motors arte out and side by side until I figure this out. Also any issue with putting the 1980 distributor in the 1974 block. ???
Proclaimer99(No Email Addresses In Posts!)
Old Nov 8, 2000 | 05:59 AM
DBF's Avatar
DBF
302 swap
They make the different pans, front sump/rear sump, usually ones for a car and the other is for a truck. Call Summit or even Ford and you should be able to get exactly what you need. Try the junk yards, there were a lot of 302 in the 1/2 tons.
Jim
Old Nov 8, 2000 | 05:14 PM
reuel_2's Avatar
reuel_2
302 swap
Hey Dude, i just pulled a 302 from my 1984 F150. I will make you a good deal on any parts you need. I have all the brackets, oils pan, distributor etc. I can send you pics of anything you need.
Old Nov 11, 2000 | 12:55 PM
hpguy's Avatar
hpguy
302 swap
Count the teeth on the dist. gear; If they have the same number of teeth then I don't see why it wouldn't work.
-Andrew
If It ain't broke, you're not tryin'!
1964 F-250, 292 V8, 4 spd/granny;
White with Black accents.
1977 Merc. Monarch, 302, C-4;
Rust with brown highlights
For Sale, $800
Old Nov 13, 2000 | 08:08 AM
TallPaul's Avatar
TallPaul
302 swap
1980Supercab
Aug 10, 2014 02:18 PM
pinegreen
17
Feb 13, 2008 07:52 PM
pinegreen
Nov 15, 2000 08:52 AM
pinegreen
Nov 8, 2000 01:55 PM
pinegreen
1983 - 2012 Ranger & B-Series
Nov 3, 2000 08:00 PM
