hey guys I was just wondering if a ballast resistor is needed for the installation of a MSD Blaster 2 coil for a late 70's 460 with stock electronic distributer? If so could a regular 0.8 ohm resistor work?
Remember the ballast resistor is a high power device, not just a "regular" resistor. The Primary resistor is 1.3-1.4 Ohms. Special high-temp connectors are required for using the Mopar type ceramic resistors in series.
and Ford Duraspark Ignitions already have a built in resistor in the form of a fusible link resistor wire that comes out of the ignition switch.
When people install NON-OEM ford equipment they should check with their website for Tech info.
One can't always luck out with people in the know at the time of the question.
I opted not to install the ballast resistor on my 351C when I installed a Blaster 2. This was an educated decision on my part and the engine has ran fine for 4 years. Of course when in doubt follow mfgr's recommendations
I had an accel coil without a ballast resistor for a couple years on my bronco with no problems. But recently, the coil started overheating, and would work for about 15 minutes. I bought a blaster 2 coil, again overheated and died in 15 minutes. changed out the pertronix points replacement, still overheated in 15 minutes. In the end, I did call tech support, and they said the coil needs a ballast resistor. I think in hindsight, I was just lucky the accel coil survived as long as it did!
Thanks for all the posts guys,thats great! Yeah Msd ought to make it a little clearer for people to understand wheather we need the resistor or not! The first thing MSD said when I called them was " does your stock ignition system currentlly have a resistor in it?" I told him NO, and he told me that I dont need one then. I guess I was wrong then? we do have a resistor ? I still believe you on the part that we dont need one on the duraspark. The tech guy said as long as you have 12v. at the coil + wire ,then you will not need the resistor. Thanks
