Coil problems
Old Sep 1, 2016 | 06:20 PM
MARC's Avatar
MARC
Coil problems
59 f100 with y block. Petronix ignition no ballast resistor. Fried 2 pertronix coils. Switched to resistor coil from Napa, still fried. Switched to non resistor coil and ballast resistor with same pertronix ignition. Have cooked 2 more coils. Only abnormal wiring is cutout switch on hot side of coil to kill power. Only use switch after truck off (extra anti theft device). Could this be dropping voltage too much to fry coils?
Any input and insight is appreciated
Thanks, Marc
Old Sep 1, 2016 | 07:40 PM
3414's Avatar
3414
Usually it takes too high voltage to fry a coil. You might want to use a voltmeter to check the actual voltage at the coil terminal with the ignition on, engine not running, ignition unit triggered. From what I recall should be right around 8 volts. Also check running, and it should be zero with key off.
Old Sep 1, 2016 | 07:42 PM
hiball3985's Avatar
hiball3985
How long does it run before the coils quit? I'm not sure low voltage would cause that problem but to high might. Have you checked the voltage at the coil?
Old Sep 1, 2016 | 07:55 PM
MARC's Avatar
MARC
Don't know if heat from intake is frying it. Coil and bracket bolts are burning hot
Old Sep 1, 2016 | 08:03 PM
Tedster9's Avatar
Tedster9
Are you running an alternator or generator? What is the running voltage?
I've run a stock generator with pertronix flamethrower, Ignitor and bypassed resistor wire for years and years, but I don't live in Tucson, Arizona either. Millions of cars ran the coils sideways on the intake like the Y without complaint, but you could try mounting the coil vertically on the firewall.
One thing that's important when installing a coil horizontal (I guess) is that the terminals should be oriented horizontal as well, not vertical. Something about the way the cooling oil is distributed or somesuch.
http://www.pertronix.com/support/tips/
Note the part about not exceeding 8 amps total.
Old Sep 1, 2016 | 11:58 PM
oldbleu's Avatar
oldbleu
Maybe a call to the Pertronix tech folks would be of value. It seems that their distributor unit is about the only thing that hasn't been replaced. Maybe there is some bad ju-ju in that part?
Old Dec 4, 2016 | 08:20 AM
MARC's Avatar
MARC
May have solved coil issue. If I direct wire coil to battery, and use remote start switch it fires right up. Bought new ignition switch. When I went to install it, I found that (I) had wired the ignition wire to the coil routed thru the acc position on switch. Rewired correctly, now at 150 miles later, no problems yet. And I now have a spare ignition switch. Duh!!
Old Dec 4, 2016 | 09:08 AM
hiball3985's Avatar
hiball3985
We all make errors at times but at least you found it and are up and running..
Moiford
Jul 11, 2015 01:20 AM
peka
34
May 20, 2015 01:20 PM
Fordboy88
Jul 6, 2013 11:39 AM
Pony Power
Electrical Systems/Wiring
Jul 27, 2006 09:43 PM
MercM47
Mar 2, 2005 11:05 AM
