MSD 6A/ 6AL
MSD 6A/ 6AL
Any one running the MSD 6a/6al box in place of there Dura spark 2 ( BLUE GROMMIT )ignition box .Curious to know what coil your using with it and how are you wiring it. (white trigger etc).I called frick and frack at MSD and forgot to ask about the coil. Emailed them last week with no reply. Frick did tell me that the resistor (ballast) wasn't needed , so I am assuming the coil needs to be changed .Thanks TR
Got the MSD installed and used the blaster coil. Also installed the MSD capacitor as I did in the Bronco years ago . I used the gray wire from the box and the Sunpro tach is alive .I am feeling a stronger steady increase in throttle .The idle is about the same. I also changed the plugs(Motorcraft) and gapped them at .054 with new wires(Motorcraft) .With only 50 miles since the install hopefully fuel mileage will increase. TR
I love my MSD, but there are a couple of things that bother me. The main thing is I go through distributor caps, and rotors, quite often. I learned that if I bought the expensive Borg Warner cap and rotor, O'reiley's offered a life time warranty. So, I have replaced them at least 4 times, free!
Another thing you should be aware of is that if you use the type of timing light that clamps onto the #1 plug wire, use extreme caution using it. Stand on a piece of wood and/or use non conductive gloves when timing. A shock from the system is quite a jolt that will make you taste your fillings.
Hmmm..
Curious about this myself...I just did a 6AL Blaster 3 conversion with DSII dizzy and I worry about cap and rotor wear now.
I like the idea about lifetime warranty free replacements as they wear...hehe
The kids who had the truck before my had the factory 84 dizzy (w/ control unit on side) that wouldn't advance and was set at 0* timing
But now she runs like a top..
I've been considering reverting to a points ignition and using it as a trigger for the MSD box. The Chinese modules are questionable. If ones dies it is without warning. Suddenly you're walking. Points go out slowly, plus, if the msd fails, you bypass it, and away you go.
I found very interesting reading on gofastforless dot com. Check the section on ignitions. The Chrysler ignition sounds fascinating.
Cool!!
I like that idea!! Vary good info on gofastforless. Thank you for the link
....will have to read it all tonight after work.
TheKirbyMan
32
08-26-2012 10:02 PM
YoungFordAddict66
04-16-2009 08:56 AM
DeathRowe
10-16-2006 06:57 PM
patsplace
12-09-2002 08:40 PM
