Normally I watch the Big Bronco discussions, but I have a general Ford question about engine serial numbers and codes...
I am looking for a web site that lists the engine codes/serial numbers for 1980's V-8 engines.
Specifically, I am trying to verify that my 1984 Ford Bronco (full size, not a Bronco II) was supposed to have a 351W and whether what is in there now IS a 351W or something else?
Bought the Bronco as a project, but I do want to use it while working on it. I am in California, so I need to get it smogged and it is already in the system as a GROSS POLLUTER, so I need to try and make sure it is equipped as it was when built, or as close as I can get.
Also, any info on a web site with vacuum diagrams for this Bronco would be great.
Thanks to all!
Jim
villadrive(No Email Addresses In Posts!)
[font size="1" color="#FF0000"]LAST EDITED ON 10-Apr-01 AT 04:06 PM (EST)[/font][p]Lots of Info Here at Official NHRA Technical Specifications Site Ford #'s from 1960 thru 2000. Also Alphabetical Listings by Manufacturer from AMC thru Shelby. http://www.nhra.com/tech_specs/engine/index.html --justmerod p.s. in Web Address there is a single underline"_"between "tech" and "specs"
