1978 - 1996 Big Bronco
power steering pump
Old Jul 23, 2007 | 05:53 PM
sb1234_99's Avatar
sb1234_99
power steering pump
I'm in the final stages of putting my 460 back together in my 78. When I pulled the truck into the garage I notice that the power steering did not work at all. I checked the fluid right away and found it to be very foamy. The fluid was actually pushing out of the cap. I think I should just buy a new/used pump. I was looking for any recomendations. I am currently running 35x14.50 boggers and plan on going to a 37 as soon as I find a good set. The truck is for off road use only. Any suggestions?
Old Jul 24, 2007 | 08:26 AM
Kemicalburns's Avatar
Kemicalburns
get a power steering pump from a fullsize van running the 460. it will work far better.
Old Jul 24, 2007 | 09:02 AM
mprice's Avatar
mprice
Are you sure that it wasn't just not fully purged, yet? To get it to purge all of the air after being refilled you will need to turn the wheel lock to lock several times with the engine running to get all of the bubbles out. I have seen where an air pocket will get left behind and when the engine is shut off it expands from the heat and shoves the fluid out of the cap.
Calvin
Old Jul 24, 2007 | 10:12 AM
Kemicalburns
if you are going to due the purge, remove the tires and have the front end jacked up. you will need to turn lock to lock 20+times
Old Jul 25, 2007 | 11:13 AM
lostin90s's Avatar
lostin90s
Napa has a Saginaw pump conversion bolts in place of stocker. I just get a Saginaw pump off ford van . Some had some not but alot better pump.
abyars111
Apr 16, 2013 05:36 PM
abe
Jan 10, 2013 07:52 PM
Blackwaterforge
Oct 25, 2012 07:25 AM
f15097
1997 - 2003 F150
Jul 24, 2011 10:16 AM
cweller
Apr 15, 2011 07:03 PM
