Power steering pump
Old Oct 22, 2012 | 09:58 AM
Blackwaterforge's Avatar
Blackwaterforge
Power steering pump
Did ford use the same pump on the Bendix power steering 65-68
as on the 69-79 power steering?
My truck (66) had the Bendix power steering.
I used manual steering from a parts truck.
I would like to add power steering using a 69-79 steering sector.
Do I also need a later pump?
Thank You!
Old Oct 22, 2012 | 12:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Blackwaterforge
Did Ford use the same pump on the Bendix power steering 65 -68 as on the 1969-79 power steering?
Bendix P/S: 1966/68 F100/250 2WD / 1969 F100/250 2WD before serial number D96,001 / P/S was not offered for 1965 F100/250 2WD's. P/S not available for F350's until 1969 w/Ford P/S.
Ford P/S: 1969 F100/250 2WD & F350 from serial number D96,001 / 1970/79 F100/250 2WD & F350 / 1976/79 F100/150 4WD / 1977 F250 4WD from serial number Y20,001 (not a High Boy) / 1978/79 F250 4WD / 1979 F350 4WD.
Bendix P/S pump (all with steel reservoir) different part number than the Ford P/S pumps with the steel reservoir, but the only thing that's different is a few internal parts.
The Ford P/S pump with the steel reservoir is essentially the same 1965/77 Passenger Cars (1972/78 without Hydro-Boost) and 1966/77 F100/350, uses the same seal kit (D1AZ-3B584-A replaced C5AZ-3B584-A).
1978: FoMoCo changed the P/S pump on ALL (except Econolines & cars with Hydro-Boost ~ both use the Saginaw pump). It's a different shape and has a plastic reservoir.
The P/S pressure hose on the pump end has a straight tube with an o-ring on it, connects to the pump with a qwik connect fitting.
Since FE engines were discontinued in 1976, there is no FE P/S pump mounting brackets that will work with this plastic reservoir pump.
Steel reservoir P/S pump pressure hoses thread onto pump.
Old Oct 24, 2012 | 08:56 AM
Blackwaterforge
Thanks ND!
Old Oct 24, 2012 | 08:04 PM
Bill W's Avatar
Bill W
Hey BWF, I just did the PS swap on my 66 and this tech read was helpful when i did mine.
How to Install Power Steering in a 2WD F100/250/350 - FORDification.com
Old Oct 25, 2012 | 07:25 AM
Blackwaterforge
Thanks Bill!
How do you like the power steering?
What year pump did you use?
Thank You!
440 sixpack
Nov 1, 2018 10:52 PM
Bulldog187th
Aug 15, 2017 11:29 AM
greentruck72
Apr 28, 2015 09:21 AM
66RangerinHB
Mar 12, 2014 11:09 PM
Spyderjohn
Feb 17, 2012 05:55 AM
