'93 351w Q's
Old May 7, 2001 | 04:23 PM
batchman's Avatar
batchman
'93 351w Q's
Hi all,
Have 93 motor Holley 650, Performer, RV cam, roller 1.7's, and long tubes. Seeking more torque, I have some old D0 heads with quenched chambers and screw in studs.
What is original compression ratio on a 93 truck 5.8? Are the pistons flat-top or dished?
Is the D0 swap a good idea? Also, how about long tubes vs shorties or tri-Y's (my current headers have rusted out) - what's best for bottom end torque?
Thanks for any/all opinions!
- Jeff
84 Bronco XLT, 151k 351w/c6 redone '95
Old May 9, 2001 | 08:52 PM
64 f100's Avatar
64 f100
'93 351w Q's
I have a 351 out of an 85, and I know there are some differences between these year models. However, I will tell on my engine the pistons are down the hole roughly thirty to fourty thousandths, and are a cupped piston (13cc I think). Since you are already carburated, I would go with the early heads. I am pretty sure that those DO heads are not compatible with the later stock injection systems.
Rich
Old May 14, 2001 | 09:47 AM
rc351w's Avatar
rc351w
'93 351w Q's
If your looking for more lowend torque, go with the tri-y headers. They give the best lowend torque. Also, if your looking to change intakes, try to find one with equal lenght runners, this will also improve torque.
RCC
Old May 24, 2001 | 12:31 AM
CantDrive55's Avatar
CantDrive55
'93 351w Q's
I believe stock compression ratio for a 351W would be 8.8
Old May 24, 2001 | 05:22 AM
dinosaurfan's Avatar
dinosaurfan
'93 351w Q's
Batch, I have never worked on anything that new but do remember putting some C9 heads on an 89, your case should be about the same. Ford started useing the same head on 302s and 351s in 1979, unfortunately they picked the 302 style- this meant smaller valves and ports (too small). The early heads also have an extra pair of manifold bolts and 'L' shaped water holes, the new heads have a big square water hole, use some good felpro gaskets intended for the 93 and assemble the manifolds and gaskets carefully. The rocker setups may be different, I would run adjustables on the thread in studs if I were doing it. The chamber design of the early windsor heads is excellent, your mileage should be the same or better, and the better breathing will help power. Check to see that your D0 heads have been updated for unleaded before you put them on. Enjoy! DF
Old May 26, 2001 | 05:18 PM
StrangeRanger's Avatar
StrangeRanger
'93 351w Q's
Jeff and Nicolle
21
Jul 1, 2010 02:46 PM
jeffj2689
16
Apr 10, 2007 12:04 PM
DictatorDanny
Jul 7, 2006 11:25 AM
jeff moon
Jan 20, 2003 05:26 PM
jeff_67cougar
Aerostar
Aug 31, 2002 08:02 AM
