351 build up: need imput!
Old Mar 21, 2007 | 05:44 PM
jeffj2689's Avatar
jeffj2689
Question 351 build up: need imput!
ok, im build a 351w for my 96 f250 4x4 with a 4.5in. lift and 35in. tires.
i bought a motor out of a 93 bronco and i'll be building that.
im thinking about this:
-ported gt40 iron heads
-1.7 roller rockers
-compression ratio of 9.5:1
-comp cam lifters, pushrods, and valve springs
-longe tube hooker headers /w dual exhaust
-k&n fipk filter
what do you guys think?? and what do you guys expect me to have for horsepower and torque?
Old Mar 21, 2007 | 07:53 PM
Tiggie's Avatar
Tiggie
What cam exactly (part number and link would be good) are you thinking about? That will make all the difference in the world.
Old Mar 21, 2007 | 10:12 PM
Conanski's Avatar
Conanski
The cam and intake will determine how much and where HP and TQ peaks are generated.
Old Mar 22, 2007 | 01:00 AM
jeffj2689's Avatar
jeffj2689
i was thinking of using the stock upper intake and using a trick flow bottomas for the cam i called cam research and im thinking of having them making me a custom cam for it and i'll get the matching valvetrain components
Old Mar 22, 2007 | 04:36 AM
HemiEater's Avatar
HemiEater
I was looking for cam researchs web site do they have one and whats there number? they did the cam in my 357Clevor....
Old Mar 22, 2007 | 08:25 AM
Kemicalburns's Avatar
Kemicalburns
locate a typhoon lower efi intake and get an edelbrock car upper and us a phenolic spacer to help lengthen the runners. the stock 5.8 upper will not bolt to anything but a stock lower just so you know and this intake flows like pooh haha. if you run 35's plan on a 4.56 gears front/rear otherwise this motor build will turn out like pooh because that heavy truck and size tires will suck the juice right out of her. your 96 is also mass air obd-II so once you get all of this stuff done see about getting a dyno tune , this will get the most out of your combo. just so you know 9.5 with iron heads will require premium fuel. enjoy
Old Mar 22, 2007 | 09:25 AM
MustangGT221's Avatar
MustangGT221
It being an F-250 it's probably not MAF.
Old Mar 22, 2007 | 11:52 AM
Kemicalburns
That is true, thanks justin
Old Mar 22, 2007 | 11:58 AM
jeffj2689's Avatar
jeffj2689
it is mass air. and OBDII. if i use the edelbrock car intake then i have to use a single throttle body and make mounts for the linkages so i want to use somthing that will bolt on
Old Mar 23, 2007 | 08:12 AM
Kemicalburns
then the efi edelbrock truck intake or lightning gt40 upper/lower would be the way to go.
Old Mar 23, 2007 | 01:57 PM
matt16875's Avatar
matt16875
Hemi, this is cam research's website
http://www.camresearchcorp.com/
I just got my custom grind from them on thursday.
Old Mar 23, 2007 | 02:39 PM
HemiEater's Avatar
HemiEater
Thanks....
Old Mar 24, 2007 | 02:13 AM
f250rollinon37s's Avatar
f250rollinon37s
my 95 f250 has mas air - just so you know -and are the later roller blocks better ? like mine - isnt a 93 a non roller ?
Old Mar 26, 2007 | 01:19 AM
jeffj2689's Avatar
jeffj2689
yes, the 93 isnt a roller motor but you dont gain much with it. and ill save money when i get my custom cam made. i only paid $250 for the whole engine and it only has 80,000 miles on it. my 96 has over 102,000
Old Mar 26, 2007 | 08:56 AM
Kemicalburns
the roller is better, and 102k miles is just getting broke in. that motor should get to 200k easy.
