Check engine light with tuner
Old Jul 24, 2007 | 09:22 PM
c00nhunterjoe's Avatar
c00nhunterjoe
when mine goes then i'll put the sd pump on, good to know its direct bolt in, its funny how the fuel filter housing on mine has no clearance compared to the sd's, did anybody else use the early 99 x-pipe or did you all use the banks one? if you arent sure about the cleance issue i'll take pics of mine and my buddies 03 for comparison, i was really worried on inital install that it wouldnt go on, had to cut the elbow for the map line off and install a pipe plug where the sensor went and you cant even slip a piece of paper in between the filter housing and the x-pipe
Old Jul 24, 2007 | 10:50 PM
RubberDuck's Avatar
RubberDuck
I used the early 99 spider too. Yeah, the clearance was tight.
freevan
Jul 26, 2014 02:53 PM
Calemut
New Member Introductions
Apr 8, 2013 11:55 AM
arkredneck
Apr 13, 2009 07:31 PM
redmt77
Oct 7, 2007 04:11 PM
2000Ford2000
Modular V8 (4.6L, 5.4L)
Jun 30, 2007 08:25 PM
