codes 1209, 1211, 1249
Old Apr 8, 2013 | 11:29 AM
Calemut's Avatar
Calemut
Hi guys, New member here;
I have a 2002 f-350 with the 7.3 turbo diesel. Utilize a Superchips MAX Micro Tuner. When I put the truck under a load, such as pulling trailor up a good grade, the CEL comes on. It will go off after a bit of driving. Each time the CEL comes on, I get stored codes 1209 (ICP system fault), 1211 (ICP sensor above/below desired) and 1249 (wastegate control valve performance). The truck continues to run good with no problems, but the codes get stored.
Old Apr 8, 2013 | 11:31 AM
Calemut's Avatar
Calemut
Some of the research I have done is pointing toward the IPR being stuck or not functioning correctly. Any help would be greatly appreciated. I am a compentent backyard mech. but not a ford tech.
Old Apr 8, 2013 | 11:41 AM
powerstroke72's Avatar
powerstroke72
Welcome to FTE.
Unfortunately, you're posting this in the wrong section. This one is just essentially for new folks to introduce themselves.
Drop down to the 1999 - 2003 7.3L Powerstroke Diesel forum and post your question there.
Old Apr 8, 2013 | 11:55 AM
patrickg450's Avatar
patrickg450
tell us about yourself
muphasa
New Member Introductions
Oct 20, 2014 03:33 PM
fastcam
Dec 3, 2009 10:07 AM
wumpum67
Jan 10, 2008 09:41 PM
gmullenix
Nov 4, 2003 05:18 PM
