Rear End Troubles
Old Jul 24, 2007 | 09:37 AM
rebelchevy02's Avatar
rebelchevy02
Well I think since the shop said your bearings in your rear diff were toast, you shuold see what happens once they are replaced, if you still have a vibration, I would really look hard over the driveshaft stuff. Just because a u joint is tight, doesnt mean its good. And its hard to diagnose them sometimes. The last one i replace, i was certain was tight, but there was no were else the problem could have been. Once i removed it, and pulled the cap, it was dry and the bearings had been reduced to dust. When i attempted to find play in it, there was none. The other three caps were had the normal amount of lube. So let us know what happens once they replace your carrier/pinion bearings! And well do our best to guide you.
vermilian
6.7L Power Stroke Diesel
May 14, 2012 07:17 PM
counciller
Oct 18, 2010 06:37 PM
lancetheman
Jun 13, 2008 04:18 PM
DaveK88
Aug 29, 2007 07:05 PM
SLE
Modular V10 (6.8l)
21
Apr 22, 2005 09:37 AM
