low rpm engine shake
Old Jul 20, 2007 | 07:40 AM
Deadabeat's Avatar
Deadabeat
my 90 2.9 shakes on low rpms sitting or moving. it all started after hitting a large hole in the road at about 50 mph. Since i have changed all the sensors over from my other motor, changed mounts, plugs ,wires,cap,rotor,set the timing, swapped ecu,ran new ground wires,checked all vaccuum, ran a compression checked which showed all cylinders holding between 95 to 110. My question is, what could cause this shaking? If you give it more gas, it smoothes out. But i noticed on the tps that there is the 5v reference, and i set the other to .95, but the ground has .04v and .05 with higher rpms, what should i do here?
Old Jul 20, 2007 | 10:24 PM
Rockledge's Avatar
Rockledge
Welcome to FTE. Have you checked the engine and tranny mounts?
Old Jul 21, 2007 | 12:27 AM
RangerPilot's Avatar
RangerPilot
Originally Posted by deadabeat
...changed mounts...
I assume he means engine mounts, not tranny mounts.
Check the tranny mount, and the geometry of the entire drivetrain. Was the rear axle knocked off of alignment slightly? All kinds of problems can creep up with mounting angles, bearings, and mounts when large holes are hit.
Old Jul 21, 2007 | 07:34 AM
Deadabeat's Avatar
Deadabeat
new motor and trans mounts, the engine shakes while sitting still, so rearend would not matter.
Old Jul 21, 2007 | 07:46 AM
Rockledge's Avatar
Rockledge
You might check over the cooling fan, see if anything is broken or loose.
Old Jul 21, 2007 | 01:11 PM
Deadabeat's Avatar
Deadabeat
checked all that when i changed the harmonic balancer, thanks, keep sending me things to test
dslpwr530
27
Aug 8, 2013 09:34 PM
dutchjarod
Jan 27, 2011 12:40 PM
tlizilani
Nov 13, 2010 11:14 PM
Deebo
Jan 13, 2009 08:14 AM
fordfan78
1997 - 2003 F150
May 21, 2006 11:10 PM
