bigger turbo
Old Jul 19, 2007 | 01:03 PM
Stroker 94 1/2's Avatar
Stroker 94 1/2
bigger turbo
I was talking to somebody a couple of weeks ago and they said with the bigger injectors and larger exhaust I should get a bigger turbo since it spools up faster. What do ya'll think?
Old Jul 19, 2007 | 01:31 PM
tjbeggs's Avatar
tjbeggs
bigger turbo's spool slower generally. with stage 1's if you are looking for a better turbo the Dominator 66 from beans would be a good choice.
Old Jul 19, 2007 | 05:46 PM
barebackjake's Avatar
barebackjake
the bigger turbo with the larger injectors are needed to have the right amount of air to burn the higher amount of fuel. and the proper flow to keep the egt's in control
Old Jul 19, 2007 | 09:50 PM
c00nhunterjoe's Avatar
c00nhunterjoe
and keep it from spining itself apart
Old Jul 20, 2007 | 10:21 AM
Stroker 94 1/2
Man $1100 for the d66. I cant afford that right now. Is there anything else I can do? Thanks guys!!
Old Jul 20, 2007 | 12:03 PM
tjbeggs's Avatar
tjbeggs
not really. the d66 is one of the cheapest options other than just a stock turbo.
Old Jul 24, 2007 | 12:29 AM
Stroker 94 1/2
If I rebuilt my turbo would it last for another couple of years?
Old Jul 24, 2007 | 07:54 AM
glasseater's Avatar
glasseater
i would just save up the money for a d66
Old Jul 24, 2007 | 08:53 AM
tjbeggs's Avatar
tjbeggs
with stage 1's maybe maybe not. depends on what kind of boost you push thru it on a daily basis. if you run it up to 30 regularly it won't last as long as if you didn't. Turbo's are very difficult to place a life span on.
Old Jul 25, 2007 | 01:41 AM
Stroker 94 1/2
I have hit 30 a couple of times but usually I don't push it to much past 20. Maybe since I don't push it too hard I can get by with just a rebuild? I plan on getting something newer in 1 or 2 years. Thanks for the advice fellas!
Old Aug 3, 2007 | 12:50 AM
Stroker 94 1/2
Well I just won a turbo of ebay from Ron's turbo service for $350. I figured this will hold me until I upgrade to a newer truck. He states in the listing that it will hold up to fuel upgrades. Did I do good on this one. I seen in other posts that some of you were giving him good reviews.
Old Aug 3, 2007 | 06:15 AM
tjbeggs's Avatar
tjbeggs
yes you did well! good job
Old Aug 3, 2007 | 02:26 PM
powerstroked162's Avatar
powerstroked162
that turbo from Ron's is just a glorified stocker. The center sections in these turbo's are junk. They fall apart when un-equal drive pressures occur. Go easy on the stocker and she'll last as long as you need her to. Good luck
Cowboy Steve
Old Aug 3, 2007 | 03:15 PM
ForemanES's Avatar
ForemanES
Aside from my compressor wheel being dusted my stocker has 250,000 and will see 30+psi everyday. Its lasted like this for some time now. I have an 00+ 7.3 compressor wheel on it now from ron it was only $20
Old Aug 3, 2007 | 09:49 PM
fishmanndotcom's Avatar
fishmanndotcom
i'm hopefully gonna put mine on next week so i'll report back with results and prolly snap a few pics of the install
-cutts-
FordManMT
Apr 28, 2011 04:13 PM
cjfarm11
15
May 19, 2009 07:26 PM
That_Guy
29
Feb 5, 2008 12:56 PM
Miner33
Nov 13, 2007 08:44 PM
wayfastwhitey
Aug 4, 2005 08:53 PM
