DP Tuner Installed
Old Jul 18, 2007 | 08:45 PM
whitetr's Avatar
whitetr
DP Tuner Installed
Well, I got my new DP Tuner today. I just finished installing it and testing it.
The toyhauler is hooked up and we are headed to Seattle. Let's see how this baby does now.
Old Jul 18, 2007 | 10:42 PM
Tenn01PSD350's Avatar
Tenn01PSD350
That's it? All you have to say? Is it working right?
Old Jul 18, 2007 | 11:19 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Come on now, you didn't do a shakedown run to get the jitters of the power out?
Old Jul 18, 2007 | 11:41 PM
whitetr's Avatar
whitetr
Unfortunately time did not allow for a flog run to see if I could break something. Instead we had to get headed north. Ran about 60 miles north to an RV park for the night. I hae to say so far, it has made a huge difference compared to my Edge Juice that I removed in the process of installing the DP. There is more power, better shifting, and I can hold 70 with a lot less throttle effort and that is on 40 tow. I haven't had the gonads to try it on 60 tow with our toyhauler weighing in at 9000 pounds without water.
Old Jul 18, 2007 | 11:46 PM
Tenn01PSD350
U R gonna like it. Have fun.
Mike
Old Jul 19, 2007 | 03:36 AM
Izzy351's Avatar
Izzy351
Shouldn't be a problem as long as you can watch your gauges (you have them, right??). Keep and eye on your EGT & tranny temp and let 'er rip!
Old Jul 19, 2007 | 10:48 AM
avi's Avatar
avi
I tow 9k lbs in the 60hp setting all the time. Keep an eye on the egt's and take it out of OD on the hills when the temps hit the limit.
Old Jul 19, 2007 | 11:09 AM
whitetr's Avatar
whitetr
Yep, I do have gauges. Being a diesel mechanic by trade, that was the first install.
Since I don't have a sig line, here is a list of mods SO FAR.
Boost, Trans, Pyro.
6637
5" Cannon w/ Muffler Delete
Zoodad
DP Tuner 40tow, 60tow, 80econo, 120race, 140smoke
ITP Overboost Eliminator
Old Jul 19, 2007 | 03:17 PM
Tenn01PSD350
Whitetr, that is a good looking list. Up next ought to be the fuel system mods.
Old Jul 19, 2007 | 04:37 PM
whitetr's Avatar
whitetr
That is the plan at this point. This is my second powerstroke, the first was a 2000 ECSB but we outgrew it. So I went searchng for an 03 CCLB Lariat. Ended up finding this one with 60,000 miles on it. Only had it since the beginning of April. So I have started over with the mods. I am going a different route this time than last.
On a different note. I pulled the toyhauler from Woodland Wa. to Kent Wa. in the 60tow mode, that is defenitely the way to go for semi flat highway driving. Rarely dropped below 70mph and had no problems passing. A huge difference from the Edge Juice I had before. Now that the trailer is unhooked, it is time to go play a bit and see what kind of power this baby realy has.
More later.
nick7.3
Oct 20, 2010 09:08 PM
titanminator
Feb 28, 2010 01:15 PM
VoodooRacer
Mar 28, 2008 10:47 AM
Go Aweigh2452
Jul 4, 2006 11:57 PM
