thread sealant for engine building?
Old Nov 16, 2001 | 01:27 PM
4byford's Avatar
4byford
What does everyone recommend for thread sealant for oil fittings on the engine block? I am running an auxiliary external oil line for a 351C (front plug back to oil press port in back) and I have had people tell me that teflon tape is not good for this application. Is there a better choice for sealant out there?
Thanks!
Old Nov 16, 2001 | 08:36 PM
Franklin2's Avatar
Franklin2
Why wouldn't a little permatex 2 or a daub of silicon work? They do make an official liquid pipe dope, but it might be a little expensive if you never use it much. I think people warn against teflon tape because people get crazy with it and it comes off and clogs up the works. If you where conservative and didn't wrap it down on the very end of the fitting, it would probably work ok too.
Old Nov 17, 2001 | 06:49 AM
StrangeRanger's Avatar
StrangeRanger
Loctite makes liquid and paste pipe thread sealants any of which will work or you can get some plain old teflon pipe dope at Home Depot, etc. Do not use any Teflon based dope on sensors or gage sending units, it will interfere with the ground.
Old Nov 18, 2001 | 11:22 AM
rc351w's Avatar
rc351w
Prematex makes an 'Aviation Gasket Maker' that is the only sealant I ever use. It looks and spreads just like molasass. I generally use it to coat and hold in place gaskets I've had myself but I've also used it for thread sealant in water and oil passages without any problem.
RCC
Old Nov 19, 2001 | 07:46 PM
4byford's Avatar
4byford
Thanks for all the input! Just wanted to tap into the collective experience of all you experts out there... appreciate it.
Old Nov 20, 2001 | 01:18 AM
StangMan's Avatar
StangMan
Silicone and oil don't go well together, something about the detergents break down the silicone and it will leak. I've never actually had any problems using teflon tape, but the secret is not to over-do it. If you put too much on, the threads won't seal properly, or wrap it the wrong way you will unwrap the tape as you screw the pieces together.
Some of that thread sealer stuff is pretty cool, and never had a problem with them either.
Later,
Ben
Old Dec 9, 2001 | 11:15 PM
Superdave's Avatar
Superdave
Old Dec 14, 2001 | 03:53 AM
The Diesel Dude's Avatar
The Diesel Dude
Use Loctite "Hydraulic Sealant" it is amazing stuff.
Brian Ski 44
May 18, 2017 12:16 PM
diyster
Escape & Escape Hybrid
Dec 10, 2015 12:24 PM
TA455HO
Sep 26, 2014 03:47 PM
Oppland
Feb 20, 2011 09:30 AM
DrCharles
Dec 12, 2009 05:09 PM
