is transmission drain plug sealant necessary
I'm doing my first ever partial drain and fill on my ford escape transmission. I've done one, and after a few days, am going to do another. My question is whether one needs to put sealant on the drain plug when you put it back in. I've found a lot of conflicting info on this. This time, based on a neighbor, I just put it back in without any sealant, and so far nothing has leaked. But I'd like to do it right this next time, if sealant is necessary. I have some teflon tape and was thinking of wrapping two layers. I'd put it just below the top of the threads so it can't get in the transmission. FYI - this is a large tapered (I think) plug that does not have a bolt head or gasket like the oil drain plug. This just has the threads to make the seal.
What do people here do? Is it necessary to seal the transmission drain plug? Is teflon tape ok?
Thanks!
Thanks!
Thanks for your reply. Are you saying do NOT use any sealing (tape or paste)? Is it supposed to just be the bare metal plug, and then snug it down to seal it?
DO NOT PUT ANYTHING ON THE THREADS!!!!!!!!!!!!!!!!!!!!!!!!!!!!
David LaPell
07-17-2013 12:19 AM
PassedDown66
05-14-2010 03:34 PM
yomamaha
07-14-2003 11:43 PM
