Ford oil dipstick question.
Old May 14, 2017 | 11:24 AM
Brian Ski 44's Avatar
Brian Ski 44
I have a 1988 4wd F250 with a 460. I am rebuilding the engine. The oil dipstick threads into the oil pan. Does it use an oring or any kind of sealant on the tube or threads?? I hate to fix an oil leak with it full of fresh oil.
Old May 17, 2017 | 12:18 PM
Brian Ski 44
I finally got hold of my Ford guy. He said no orings, or sealant. The taper fit should seal fine. Hard to tell if it leaks I had an oil filter gasket blow out on start up. Argh...
Old May 17, 2017 | 12:20 PM
Freightrain's Avatar
Freightrain
Ya, should be just a tapered flare fitting, like a brake line.
Old May 17, 2017 | 12:25 PM
Brian Ski 44
Well not quite a tapered flare like a brake line. It was a tube with a ridge about an inch from the end. More like a hydraulic line. That was what had me puzzled.
Old May 18, 2017 | 12:16 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Brian Ski 44
I have a 1988 4wd F250 with a 460. I am rebuilding the engine. The oil dipstick tube threads into the oil pan.
No O-ring or sealant used on the oil dipstick tube.
Only the A/T dipstick tube uses an O-ring.
CapePowder
1997 - 2003 F150
Sep 8, 2016 09:13 PM
ol-blu
Sep 3, 2012 08:50 PM
Serapis
Apr 24, 2010 12:30 AM
Baxtjh
Mar 12, 2010 05:20 AM
Larry Mizek
Sep 17, 2005 08:16 AM
