However, being that I am on the other end of that spectrum (the repair facility), I can tell you that 99 times out of 100 I would rather the General put in lights or "glorified idiot lights" instead of "real" gauges. Customers don't generally like that their oil pressure drops when idling (because they don't understand) or that the coolant temp gauge sometimes reads 230 degrees (normal). It sucks when you try to explain why the gauges move. Most folks don't need to know...a light is more than enough. For towing/problem children vehicles that NEED to know, that's fine....and the customer KNOWS what to look for. However, in an "A-hole van", there is absolutely NO need for gauges.
That may all very well be true, but if I want gauges, then they should be GAUGES, not idiot lights. If Ford wants to put in idiot lights, then put them in. But don't make them so bad that they show hot when it's too late! What good did that just do? You made the idiot a pissed off idiot because he had no idea anything was wrong until the radiator or trans spewed everywhere, or the motor locked up from no oil. And THEN the gauge moves. My neighbor had a Ford van where the JiffyChange forgot to tighten the oil filter AND plug. If he had more than glorified idiot lights, he may have seen the oil pressure going screwy before it dropped to zero the same time the motor locked up. Sorry, I don't buy it. Fortunately, the JiffyChange did, and they ended up with a new engine...
Cheese and Rice, Batman!!! I didn't mean to offend you. Holy cow.
I'm just saying that for me to diagnose a "problem" under warranty, it costs ME money because I have 18 minutes to tell them that it's NORMAL........unscrewing the sender (likely by "braille" method), install an adapter, run a hose and gauge, tape it to the windshield, drive it, then write a detailed description of what I did.
Sorry I said anything.
Yes and they just drove 53 miles to get there and the engine is cooking your hand.
No, you didn't offend me!!!! It just really gets my goat that *FORD* did that. The trucks need real gauges, not idiot lights. I would have preferred real gauges on my Ranger too, but did I *need* them, probably not. I would even argue that the 150 should have real gauges. I understand what you're saying -- my background is in service (not automotive), but telling a customer that their "problem" is completely normal operation of the device when they clearly don't like it acting that way is never pleasant. I just think it's a big mistake to make customers believe they have real gauges when they don't (look how many folks ask the question that started this thread).
Didn't mean to offend YOU!
So how do the other car companies do it? MB used to have an oil pressure gauge that read 3 bar anytime it went over 2000 RPM (assuming oil and pressure is there) and before that, it was variable so you do get an idea of what is happening. My 91 Firebird had a gauge that reads oil pressure too. If it was such a problem, wouldn't other manufacturers have that same issue? Currently, my wife's MB has a readout that will inform you if oil is low and/pressure is low. No gauge. Fair enough. But to give a gauge that is little more than an idiot light, IMO, is deceptive. You are telling me that there is a gauge but it doesn't really work. Kinda like a kiddy cell phone.
