window wont rolldown - 99 F350
I've got a problem with my window not rolling down. the dealership told me it was the motor so I changed that myself (super easy) but that did not solve the problem. when I first installed it I hit the button and it went up a tiny bit so I know it will roll the window up but when I try to roll it down I just get a clicking sound under the dash. I switched the relays around and it does the same thing no matter what relay is whatever spot. Does anyone know what my problem could be?
ok now this is wierd. I cut the wires coming from the rocker switch and crossed them to see if the motor would turn the opposite direction and now it works both ways and the relay doesnt click anymore. unless someone see's a problem with that I'm just going to leave it alone and call it good. i dont even care if the switch works backwards at this point.
