Changing front rotors on PS F350 4X4 DRW
Anyone know how to get the hub extension plate off so you can remove the rotor. Mitchell and 2 other manuals say that you just remove the hub extension bolts and remove the extension. I have tried this and the extension won't budge a bit.
Again the vehicle is a 1999 SD F350 4x4 DWR
Thanks for any info.
Do you have the rotor and hub extention off the truck?
If so,then look behind the rotor,there are nuts that you need to remove.
Mine were stuck on there pretty good. I had to remove them to install my Warn premium manual hubs. Just take the nuts off and grab a good size rubber mallet, hit outward on the spacer, turn the hub...hit...turn the hub...hit. Just keep doing this and it will eventually break free.
Oh yeah, for those that are interested, Warn premium manual locking hubs DO work on duallies. You just have to remove the wheel spacer and grind the lip in the middle of it. They work like a champ!
justplumducky
05-23-2014 08:50 PM
88gtblack
11-15-2013 10:08 AM
jdbanks
05-17-2005 02:47 PM
jdbanks
05-16-2005 07:49 PM
