2000 ford excursion front end clunking noise
Old Jul 6, 2007 | 08:00 PM
samanguiano's Avatar
samanguiano
I Had A Clunking Noise When I Hit Any Type Of Bump. It Was The Stabalizer Link (pin) Passender Side. My Guess It Was Due To The Heat From The Exhaust Since It Seems Most Excursion Owners Heard The Noise From That Side The Most.i Didnt Know Where The Noise Was Coming From Because The Pin Looked Good But I Did Notice The Truck Swayed(thus Anti-swaybar) At High Speeds Alot. That Was My First Clue The Second Was You Could Rotate It By Hand Easily.took It Loose And Drove It No Noise. If You Hear A Noise When You Accelerate Or Stop Its Probably Your Ball Joints. To Check These Put The Front End On Some Stands And Pull On Top And Push On The Bottom Of The Tire At Around.you Can Check For Play On The Bearing Also. You Will Need A Buddy To Look While U Shake. Any Play Or Movement Is No Good Sam.
Old Jul 7, 2007 | 01:00 AM
Monsta's Avatar
Monsta
Sit. Stay.
Aloha, welcome and thanks for the tips!
xSgtRenegadex
16
Aug 15, 2014 11:03 AM
Ford in progress
13
Jan 6, 2012 10:28 AM
Jager
17
Jan 10, 2011 01:10 PM
homesteader
20
Nov 16, 2010 03:06 PM
ckstrawser
25
Dec 22, 2009 09:57 PM
