tran id ?
Old Jul 5, 2007 | 07:15 PM
Lee250's Avatar
Lee250
tran id ?
I recieved 3 trannys from a friend. One is a 3 speed standard out of a mustang. One is a c4 out of a mustang. And the third I don't know. It is about 2-3 times heavier than a c4 but looks like a c4. I'm thinking it is a c6 but I don't know. How can I tell? Here is the number off of it E0AP-7008-CA. Any thoughts?
Old Jul 6, 2007 | 06:12 PM
Lee250's Avatar
Lee250
is it like rearends where you can tell by bolt pattern/number?
Old Jul 6, 2007 | 08:40 PM
mhg's Avatar
mhg
go to top of page and look in aqrticles and specs
trans id section
Old Jul 7, 2007 | 08:35 PM
Lee250's Avatar
Lee250
Thanks. I have another one for you. I have a 74, if you decode the numbers and letters it says its a 74, 3 speed manual trans that I recieved from the same guy but I have no idea what it is or what it is out of. It is kinda long and the shifter is at the very back right above the output shaft. I think it is out of a car cause it has a very short shifter.
Old Jul 9, 2007 | 12:02 AM
85e150's Avatar
85e150
That sounds like a three speed out of a Mustang. But it wouldn't be a '74....
Top loaded iron case? Side mounted shifter linkage?
That trans would have been last used in a Mustang or Cougar in the last year of the old style car, which was what, '72 or '72?
Old Jul 9, 2007 | 12:58 AM
78ltd's Avatar
78ltd
Funny you should be asking that question. I too have that
transmission I pulled out of a 79 T-Bird I had. The engine is
original to the car, but obviously the trans isn't. If it's a removeable
bellhousing, it's not a C6, that's for sure. Mine has the vacuum
modulator on the driver side. Does yours? I think it's the last of
the line FMX's. They were used through 1980. I also can't get
anyone to tell me an answer. But I really think it's an FMX.
Old Jul 9, 2007 | 01:00 AM
78ltd's Avatar
78ltd
Also, the three speed trans was used in the Maverick/Comet
line which were available with floor shift. It could be from
one of those. The last year for the Mustang/Cougar application
was 1973.
Old Jul 9, 2007 | 11:47 PM
85e150's Avatar
85e150
Didn't the GRandad use the old 3 gear too?
Old Jul 10, 2007 | 04:24 PM
78ltd's Avatar
78ltd
Yup, the Granada/Monarch used it also. I guess an early
production one could have used a 74 model year trans.,
although they came out as 75's. The introduction date
was Sept. 21, 1974, so I imagine production ramped up
around May/June of 74. Come to think of it, my 1973 maverick
(built in June 73) had the original AC compressor on it
and it has the 1974 Mustang part number on it. The Mustang
II was introduced in the Spring of 73 as an early 74 Model.
Old Jul 11, 2007 | 12:11 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Maybe this will help.
1979 Thunderbird
D9OP-DA / 302 - Trans ID: PEE-M14 = C4
D9OP-EA / 302 - Trans ID: PEE-V13 = C4
D9OP-KA / 351M - Trans ID: PEF-AA7 = C4
D9OP-HA / 351M - Trans ID: PEF-AB7 = C4
D9OP-NA / 351M - Trans ID: PHB-AT3; AT4 = FMX
D9OP-GA / 302 - Trans ID: PHB-BG = FMX
D9OP-GC / 302 - Trans ID: PHB-BG1; BG2 = FMX
D8OP-AA / 351W - Trans ID: PHB-Z9; Z10 = FMX
D9OP-MA / 351M - Trans ID: PJA-DK; DK1 - C6
Old Jul 11, 2007 | 10:21 PM
78ltd's Avatar
78ltd
Thanks NumberDummy. However my transmission case is E0AP.
And the tag is gone. I think it's an FMX because of the modulator
on the driver side rather than passenger side and it has a removable
bellhousing. You are an invaluable resource. And we ALL Thank You!
onadraw
Dec 9, 2015 07:57 AM
51dueller
Dec 30, 2014 09:02 PM
Shadowrider123
Jun 29, 2014 09:53 AM
seafire
21
Nov 28, 2010 05:05 PM
cvr_
Dec 14, 2002 08:18 PM
