C4 transmission
C4 transmission
I have a question about a C4 transmission that came out of a 66 Mustang. I posted the same question on the transimmision forum. But thought it might not hurt to post it here. I have a 70 F100 2wd with a 74 302 for a engine. I'am new to automatics so I not sure it will mount up. I don't want to purchase this tranny and not have it mount up.
yes it will fit the 6 cyl, 289,302,351w and 351 c will all bolt up the only issues are there is 2 different flywheels one has 164 teeth and one is 157. The other is in 1980 the 302 balanceing changed under 1980 they where 28 ounce after1980 the are 50 ounce.so if you find a 80 or newwer you have to use the older flywheel.
Hi cj06, can you elaborate on your statement. I'm thinking of going for AT for my 1970 F-100, myself. I have no experience with either, but so far my reading/assessment: C4 is more durable, light and suitable for street use & C6 is heavy/robs more power, and suitable for off-track use....
Enlighten me, please.
Thanks
Thanks
c-4s were never put into any trucks and will never hold up to any type of work that the trucks were designed for !
the reason a c-4 uses less power is they are smaller , all the insides have smaller diameter
clutches , drums , bands , less friction material to help the power to get to the rear end !
the mustang weight was around 2600 # ,
F-100: 1/2 ton (5,600 GVWR max) per Wikipedia
now that is twice the weight for the truck and with the increase in weight you also
have to increase the size of the tranny to hold up to it !
Small block C6
There were several different cases for the C6. One for FE engines, one for the 429/460 and 351M/400 engines, and one for small block Ford engines. The small block C6 would probably be best for your F100. Ford did put C4s in some pickups. It was slightly different from the Mustang transmission in that it had a heavier output shaft and yoke as well as additional clutches internally. The pickup version of the C4 would be OK, but I do not recommend using the Mustang transmission unless you modify it with the extra clutches. The small block C6 would be the best.
It will work,I had a little more of a problem. I had a 84 / 302with the granny gear transmission somebody had put in my 79 f-100 . Transmission was bad and I wanted an automatic. I had a 66 mustang c/4 , pan fill transmission. The engine is 50 oz. balance so i used an AOD flexplate of the right size , changed the standard transmission starter for an automatic transmission starter and it's been operating about 6 months now. I like lots of power ,for no good reason that i can think of ,so my extra 460 with a c/6 will be going in next spring. Yes , to the naysayers,I know my MPG will drop from 18 mpg to 10 mpg, but i don't care,you only go around once . I'm pushing 70 years and plan to have a little fun while i'm still here L.O.L. , my daughter can drive her prius and save enough fuel for me to wast it L.O.L.
