E4OD Converter Over Heats
Old Jul 10, 2007 | 11:39 AM
JQ's Avatar
JQ
I've owned my '92 F250HD 4x4 7.5L since new. The truck is stock except for a Banks intake and exhaust system.
From the beginning I've had a problem with the converter. When traveling slowly off-road (even on moderate grades) for a period of time; or when backing with a trailer up a grade, the converter overheats and spews trans fluid from inside the bell housing (not the top vent). I lose about a 1.5 quarts. After it cools, there is no leakeage of fluid. The trans temp stays normal (the guage is reading at the pressure test on the trans housing so it doesn't see the converter temp). There are no other signs of incorrect operation.
I had Banks install a Trans Command module (problem existed prior to install). I went to an oversized cooler and conducted a flow check that showed normal. Ford replaced the trans and converter in 1998 with the then latest E40D mods and it made no difference.
I've been to many trans shops and to Ford with the problem. Each time I've drawn a blank. Has anyone else had this problem? Any suggestions?
Old Jul 10, 2007 | 02:31 PM
Casey's Avatar
Casey
My suggestion is to ditch the Banks trans command. It's making the problem worse. It raises line pressure, and if the pump has a hard time maintaining line pressure it cuts flow to the torque converter. Now the converter has NOTHING to cool it, and it will get HOT!
The second thing that will help is better trans cooling. Keep the cooler in the radiator, it's a big help at low speeds. Change the air to oil cooler for the biggest you can find. A cooler from a 6.0L is about the best cooler out there. An electic fan blowing on the air to oil will also help.
Old Jul 11, 2007 | 05:44 PM
JQ's Avatar
JQ
I'll experiment with operating without the Banks, but the problem was occurring prior to the Trans Command module install.
Old Jul 12, 2007 | 06:58 AM
Casey's Avatar
Casey
I didn't say the Banks caused it. I said it's making a bad situation worse. Read the rest of my post, above.
