1965 F100 floor pans and radiator support
Well, it depends. The '65 could have either a straight front axle or a Twin I-beam front axle. There are two distinct core supports and floor pan shapes that go with each style. There is a repro core support that fits '61-'64 that can be modified to fit the '65/'66 Twin I type parts. Try a search for core support, this question comes up often.
BTW, Welcome aboard!!!! There is some awesome help here!
This is a thread that has some info on the earlier core support and what must be done to fit the '65.--->>core support<---Click here
Hello
The floor pans from the later model trucks do fit with little modification. I havent personally done this but I know it has been done alot. The front end of the 65 and 66 truck is all the same virtually up until 1979. For the rad support you must buy a 61-64 model reproduction and it can easily be modified to fit your truck by cutting and welding the current fender and inner fender supports. It may require a little modification but its really the only option if you wanna go new.
DSparksF250
13
06-05-2017 08:15 AM
AlsRyd66
05-07-2017 08:30 AM
