Radiator support
Old Jun 19, 2017 | 12:20 PM
thisandthat's Avatar
thisandthat
Radiator support
So....
Looks like no one makes a 1966 2wd f100 radiator support?
Looked at LMC and they had nothing. Some forum threads show this as well.
Anyone know if I can modify a 65, or 4wd, or f250 support? How much work would that be?
Is there a different path to go down?
Thanks
Jonathan
Old Jun 19, 2017 | 01:56 PM
daveengelson's Avatar
daveengelson
Welcome to FTE!! Ran an 'advance' search and found several threads on topic. If not familiar open the search menu at the top and scroll down and open advance search, write in topic, then narrow search to the 61-66 forum. Posting couple thread may find helpful?
1966 Ford F100 Restoration: Using the reproduction core support
https://www.ford-trucks.com/forums/1...or-66-use.html
Copy of post by Bill (NumbersDummy)** Suggest bookmark Bill's post if info applies.
C2TZ16138G .. Radiator Support / Obsolete/Reproduced
Fits: 1961/64 F100/250 2WD & 4WD / 1961/66 F350/600 / 1965 F100/250 4WD / 1966 F250 4WD.
C6TZ16138B .. Radiator Support / Obsolete-not reproduced.
Fits: 1966 F100/250 2WD.
C6TZ16138C .. Radiator Support / Obsolete-not reproduced.
Fits: 1965 F100/250 2WD / 1966 F100 4WD
Again welcome to FTE!
Old Jun 19, 2017 | 06:09 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1966 Ford F100 Restoration: Using the reproduction (C2TZ-16138-G) core support
Copy of post by Bill (NumberDummy) ** Suggest bookmark Bill's post if info applies.
C2TZ-16138-G .. Radiator Support / Obsolete/Reproduced
C6TZ-16138-B .. Radiator Support / Obsolete-not reproduced
C6TZ-16138-C .. Radiator Support / Obsolete-not reproduced.
Several years ago, someone said that LMC had repro'd the C6TZ-16138-B 1966 F100/250 2WD radiator support.
But I've never seen any proof of this, as no one has posted a link to LMC's catalog and I'm not looking, because every time I do, I get p!ssed off due to LMC's WRONG and misleading info.
Old Jul 3, 2017 | 03:16 PM
TxStang2010's Avatar
TxStang2010
the 66 2WD is not reproduced by anyone . You can find a better used one but that may take some time and you will pay a premium price for it , you can do like I did and rebuild the one you have which is time consuming and frustrating , you can also get a used 65 and either use the 65 radiator or modify it to use the 66 radiator ( only major difference as the use the same inner fenders . you can also get the 61-64 support and remove the rounded inner fender mounting points and install the ones off a 66 and modify the radiator area on that one as well ...... all options are a lot of work .
Looking back on the work it took to repair my support on my 66 i would seek out a used one in better condition or pay someone to repair it .
Old Jul 4, 2017 | 11:09 AM
thisandthat
Thanks all
Old Jul 4, 2017 | 09:43 PM
664x4drvr's Avatar
664x4drvr
Obsolete and classic auto parts Inc Oklahoma city ok
61 - 66 may need some fabrication
Old Jul 5, 2017 | 10:18 AM
NumberDummy
The only radiator support that was used 1961/66:
C2TZ-16138-G .. Radiator Support / Reproduced
1961/64 F100/600; 1965 F100/250 4WD; 1965/66 F350/600; 1966 F250 4WD
66with352
Apr 13, 2016 09:16 PM
66f100rat
Feb 11, 2013 07:48 AM
blacburn10
Feb 5, 2013 08:55 AM
kylejhowe
Aug 25, 2010 07:41 PM
fordtruck44
Aug 13, 2008 06:55 PM
