1966 Radiator Support
Old Feb 27, 2007 | 12:38 AM
RTRF350's Avatar
RTRF350
I am in the process of restoring a 1966 F-100 Pickup. I need a new radiator support for it. It is the panel that is mounted right behind the grill. The one that is on the truck now has rusted in to at the bottom. I have found a panel that says will fit a 1964 but cannot find one for a 66. Will the one for the 64 fit and if it will not, does anyone know where I can find one?
Thanks
Old Feb 27, 2007 | 05:09 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by RTRF350
I am in the process of restoring a 1966 F-100 Pickup. I need a new radiator support for it. It is the panel that is mounted right behind the grill. The one that is on the truck now has rusted in to at the bottom. I have found a panel that says will fit a 1964 but cannot find one for a 66. Will the one for the 64 fit and if it will not, does anyone know where I can find one?Thanks
Welcome to FTE
1966 F100 4X2's use a one year, one model radiator support (C6TZ-16138-B). While the book shows that the 1964 core support (C2TZ-16138-G) will work on 1965/66 F250 4X4's, it won't work on a 1966 4X2. You might do a search. This is a well discussed topic here at FTE. It may be possible to modify the 1964 support, but I have no knowledge about doing that.
My only question is...how do you know the one you are looking at is from a 1964? Did you see it listed in some catalog?
Old Feb 27, 2007 | 05:43 AM
banjopicker66's Avatar
banjopicker66
Our Slicks club compared original 64 - '66 core supports to one of the repops now being offered. I bought the repop, by the way, because it was $250, and the originals are in excess of $500.
The quality is good, and all the holes match up for '64.
It has the holes punched for the inner fender support brackets.
It has the radiator bracket for the '65 and earlier radiators.
The 2 issues you will face are the inner fender supports, and the radiator support bracket.
A friend of mine used his rotted support as a template, and mounted the '65/'66 inner fender mounts on my repop support.
I will use my newer '66 rdiator, and take the brackets of if it and turn them around.
This should make it work when I get around to installing it.
Old Feb 27, 2007 | 05:33 PM
66 POJ's Avatar
66 POJ
Hey Banjo, are you saying to swap sides with the brackets that are on the radiator now and they will line up with the '64's core support? I am thinking of doing this also as my support is gone below the battery, seems like a common problem.
Old Feb 27, 2007 | 05:38 PM
66 POJ's Avatar
66 POJ
OOPS! Where are my manners, Welcome RTRF350! This is one of the best places for help on our trucks! The two who answered you are like...........
Amazing!
Old Feb 27, 2007 | 06:54 PM
banjopicker66
RTRF350: Forgive my poor manners, and let me also welcome you to FTE!
Yes, 60POJ, that is exactly what I am saying!
Old Feb 27, 2007 | 07:52 PM
66 POJ's Avatar
66 POJ
Thank you Banjo, I am going to get a new support and do the same. I've got mine rigged with some 1" stock. I'm sure it looks much better.
66with352
Apr 13, 2016 09:16 PM
kyle j
36
May 21, 2015 06:01 PM
Andy1966
19
Sep 23, 2014 03:54 PM
nineteensixt5f100
13
Jul 8, 2014 04:04 PM
JoeVR5
21
Jul 24, 2013 09:43 AM
