Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Need a left hand thread bolt....help
Old Jul 5, 2007 | 04:30 PM
laynrubber's Avatar
laynrubber
Talking Need a left hand thread bolt....help
I need a 1/2 inch, left hand, FINE threaded bolt, actually i need 3 of them for a tool i am making. It is puller for a non Ford truck (Plymouth brake drum) and i am having a tough time. Tried all the bolt supply places in S'toon, couple places in P.A. and no luck. A machinest could cut me some but 2 to 3 weeks and i need to pull these drums ASAP.
Another alternative is to beg or borrow a tapered brake drum puller......anyone have ????
I tried ebay all winter but i wasn't dropping $130 on a tool i could make. Well i might pay that today but not then.
Old Jul 5, 2007 | 04:37 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Are you near any aircraft parts stores?
If you didn't need a fine thread, a wheel lug bolt might work. Buick used lug bolts for years, right = right hand thread; left = left hand thread.
Old Jul 5, 2007 | 04:52 PM
Fomoko1's Avatar
Fomoko1
Bolt Supply 931-1960 (I talked to Rob) in Saskatoon can obtain this in a threaded rod, approximately 2 days away.
If you like I could pick it up and throw it on the bus if they can`t do that for you.
Old Jul 6, 2007 | 01:04 AM
laynrubber's Avatar
laynrubber
Are you "connected" or a "made man" Morris ?
I called there today and someone there said nothing in stock (obviously) and it would be 2 weeks. Well Yorkton is fast approaching and i can't wait too long.
I will call them again tommorow, or i'll call you.
Old Jul 6, 2007 | 01:10 AM
laynrubber's Avatar
laynrubber
I also at the end of the day called Arnie Holmes of Specialty Cars in P.A., he has some L/H threaded wheel bolts from said vehicle. I got to thinking i could weld a conventional 1/2" bolt to the head of the unconventional bolt, then it will thread into the brake drum and be long enough to put a conventional nut on the welded end AND PULLLLLLLL.
Arnie is a very talented guy, sometimes so is Shaune
Old Jul 6, 2007 | 01:42 AM
Fomoko1's Avatar
Fomoko1
Good stuff, you`re on your way to Yorkton soon...
Old Jul 6, 2007 | 07:50 AM
96sherm's Avatar
96sherm
welll....i was going to run down to fastenal but sounds like ya got her covered!! good to hear you'll be in yorkton!!!
Old Jul 6, 2007 | 12:39 PM
laynrubber's Avatar
laynrubber
Welllllll, i will be there whether i am there with 4 brakes or 2 front brakes.
Old Jul 6, 2007 | 01:42 PM
96sherm's Avatar
96sherm
i like the 2 brakes idea...more exciting...
Old Jul 6, 2007 | 01:44 PM
loudfords's Avatar
loudfords
2 fronts are better than 2 backs any day! Backs keep locking up without stopping at all. Rather embarassing.
Old Jul 8, 2007 | 10:48 PM
laynrubber's Avatar
laynrubber
Well this thread is done.
I got 3 L/H bolts from Arnie in P.A. and am welding them to 3 longer bolts so the puller will work now. Should be doing that tonight but need to go gto sleep instead tonight.
Morris, Rob could have gotten me L/H threaded rod, 3 feet for $55 where i needed 9 inches but thanks for the help anyway.
Old Jul 8, 2007 | 11:05 PM
Snowking's Avatar
Snowking
phh call me when you got one chicken LOL my dads 85 Ford F150 has one front one and we pull a 20ft gooseneck with it, but then we got seat belts
Encho
1978 - 1996 Big Bronco
26
Jun 17, 2022 09:37 AM
73 Crew
Oct 20, 2014 08:40 PM
K.Ray
Mar 20, 2014 09:49 AM
robertbruce
15
Feb 5, 2013 09:47 AM
drew96
Apr 20, 2006 09:48 PM
