Gearing question..
Old Jul 1, 2007 | 05:04 PM
snurtle112's Avatar
snurtle112
Gearing question..
i just purchased an 01 excursion v10..the X has 44's tires.thespeedo is calibrated correct.when im doing 60mph im at 1550rpm with 44's tires.can anyone get an idea of what kind of gears i have?i cant imagine there still 3.73 or 4.10
Old Jul 1, 2007 | 06:29 PM
kermmydog's Avatar
kermmydog
Under Articles/Spec there is a calculator for gears/rpm/etc
Old Jul 1, 2007 | 06:34 PM
snurtle112's Avatar
snurtle112
thank you appreciate it
Old Jul 1, 2007 | 06:52 PM
snurtle112's Avatar
snurtle112
i tried but i dont understand how its going to tell me what size gears i have
Old Jul 3, 2007 | 10:36 PM
79 Fordnut's Avatar
79 Fordnut
Under the "MPH RPM" heading is a calc for gear ratio. Plugging in your numbers gave this result, Gear Ratio = 3.3829365079365That does not sound like a factory ratio to me, but it is close.
The other option is to make a mark on the driveshaft in a convienient spot, lift a tire off the ground, place tranny or t-case in neutral, have a helper rotate the tire one revolution while you count the number of turns the driveshaft makes. Still approximate but usable. If the axles is posi/locker you need to lift both tires off the ground. Hope that helps!
fordmanva
Mar 13, 2012 09:23 PM
Ford150/428/dud
Offroad & 4x4
Sep 23, 2008 08:51 PM
1984/351
Mar 13, 2007 10:27 AM
bigsub
Jan 25, 2005 08:34 PM
highboy 74
Offroad & 4x4
16
Sep 8, 2004 12:11 AM
