FPR Regulator screens
I know there has been a lot of posts on this subject, but I have an idea for you all to consider. Really it happened by accident to begin with. When I was cleaning mine I losed the srceen in the valley. Well I have found that in just a few months of running with out the screen that all the gunk of course just goes into the main fuel filter. Well that filter is suppose to be changed yearly. I thought that it would be a better idea to just run with out the screen and change you fuel filter like you should then you wont ever have to clean a screen again and the gunk is still removed every time you change the filter. What do you guys think? It just seems more simple to me. One instead of two.
I would like to know whats worrying you about this Cowboy Steve. I cant think of any adverse effects. I remember talking to Tim about it when I lost my screen, and he said that he wouldn't worry about it. I'm just thinking if you change your filter like you should then you would be just fine. I found all that crap you clean out of your screen in my filter. Now all I have to do is change the filter and not even worry about a screen. Sounds easy to me.
Originally Posted by IDMooseMan
When I had the dealership change my fluids and filters (I know, I know, but I've had two surgeries in the past two years, so I don't care) they didn't mention anything about the FPR screen. Maybe I should take a look at it, just to make sure.
The screen is after the FPR.
Fuel from the FPR goes to the return line for tank. The screen is a tee for the filter housing to the return line. The screen is installed so dirt will not travel thru the restrictor and back to tank. The reason for the hole with screen is so the housing can bleed the air out and keep fuel cooler by returning back to the tank. It has a restrictor in it and can clogg. I think the restictor is .020
Bill
Bill
on
I would say its ok to run it for a short period of time but as already said it does keep the big junk out of the regulator. The fuel actually is flow out of the housing through the screen and out to the return line. so the fuel filter really isn't in the equation. You do run in danger of plugging that restrictor. which by the way I had idea was that small!
I understand what your telling me there Tim, but I'm not sure its right. You say the flow is going out from the fuel filter canister. I remember that when I cleaned my screen all the gunk was on the wrong side then, and now when I check my fuel filter all that gunk is right there on the same side in that same area of my fuel filter as if that is where it comes in not going out and the filter catches it there. Maybe my truck is the one in a million that everything runs backwards. I'm not sure that just what I remember and I can see when I pull mine out.
Casey, the fuel flow is just as madvan explained. I think the screen is there for when the filter is changed out, it's the only time I can think of when un-filtered fuel may get to the restrictor. Small pieces might be left behind if the housing wasn't cleaned thouroughly. .020" is pretty small so it could can happen. I'm just guessing but it seems the only thing that could cause the restrictor to get plugged, besides, engineers usually don't put filters where they are not needed. You might be OK without it but you'll not know when the restrictor is plugged, you would be running some pretty hot fuel to the fuel system.
Casey
The unfiltered fuel flows out of the cannister thru the screen thru the restrictor and to the return line. Think of it like this if you remove screen then you will clogg the restrictor. I rather clean the screen. This passage is so fuel will not overheat and to remove air/foam from the system (low pressure side). Thus the reason for a more responsive motor after a cleaning. (air/foam removed).
Its a bad idea to remove screen for the long run. Temp would be ok.
Bill
Bill
The location is easy. If you are looking at your motor from the front of the truck it is on the right side of the fuel filter canister. On that side you will find two 10MM bolts that hold it(FPR) on the fuel canister. If you remove those bolts you will find a rubber o-ring and the metal screen we are talking about. Be carefull that they dont fall into the valley. It will be hard to find if it falls down there. It is not magnetic.
From what your saying I guess I need to replace mine. I guess not all ideas can be good ones.
