cut tire!
Old Jun 29, 2007 | 07:15 AM
  #31
tjbeggs's Avatar
tjbeggs
Originally Posted by tndiesel
Since it's just the rear outside tire all they will need to do is replace and balance rght? Maybe I should get them to install the long valve stems for two rear inside tires.
You don't ahve to replace it with the same brand and tread but it is a good idea. The reason being that your tires have a lot of tread left and even though tires sizing numbers are universal. The actual dimensions in inches it a bit different. Different brands could be 1/4 inch different in hieght. It really won't hurt anything but I usually try to keep the same brand tires together. But I also understand if cash is tight.
The important thing is to replace it ASAP. As far as your valve stems yes now would be a good time to get the valve stems done too. At least on the side with the bad tire. then you can deal with the other side later.
Old Jun 29, 2007 | 08:13 AM
  #32
powrstrkr's Avatar
powrstrkr
I would trash it or maybe keep it for a spare if it holds air. A few years ago I got a similar cut in a BFG in normal street driving, and it blew out. My Bronco off road rig had BFGs for years and I never had that happen even though I'm on rocks all the time.
Old Jun 29, 2007 | 08:52 AM
  #33
tndiesel's Avatar
tndiesel
O.K. I measured it exactly very gently with a flathead screwdriver and at it's deepest point is barely 1/8th of an inch. When you peel it back all you see is just solid rubber. It seriously looks worse in the pic.
Old Jun 29, 2007 | 08:59 AM
  #34
BadDogPSD's Avatar
BadDogPSD
Great idea! I vote for replacing the damaged tire also. Check TireRack. They normally have really good prices and have a network of installers they can refer you to for the install.
Old Jun 29, 2007 | 09:00 AM
  #35
Neal 97 250's Avatar
Neal 97 250
You may have them put in since you have it apart.
Old Jun 29, 2007 | 09:01 AM
  #36
tjbeggs's Avatar
tjbeggs
If it only an 1/8 of an inch it probably ok. But keep a close eye on it.
Old Jun 29, 2007 | 09:03 AM
  #37
Neal 97 250
Just be sure that you never get to wher eyou see cords it may be too late at that time. PS: keep avery close eye on your pressure because if it is low and over heats KA-POW
Old Jun 29, 2007 | 09:30 AM
  #38
61 uni's Avatar
61 uni
it's on the back. drive it. you have another one on that side if it goes out.
Old Jun 29, 2007 | 04:48 PM
  #39
powerstroked162's Avatar
powerstroked162
Wow, Im sending BFG specs to you foo's, lol. Sidewalls are 7/8" of an inch thick. 1", 7/8" same thing. Point being you should just replace the damn thing. This case has gone on way to long and im runnin outta ice cream to keep provin my point. Brother Rubber, I'll send ya sidewall specs ASAP.
Cowboy Steve
Old Jun 29, 2007 | 04:49 PM
  #40
powerstroked162
WTF?/?/?/?
Cowboy Steve
Old Jun 29, 2007 | 07:08 PM
  #41
tndiesel's Avatar
tndiesel
Cowboy Steve
Fill that bowl up with more cream. IF it is barely 1/8 in.deep then I got 6/8 in.eft right? Still replace it?
Old Jun 29, 2007 | 07:13 PM
  #42
powerstroked162
6/8 would be 3/4. I cant tell you wether to run it or not. At this point all my boys are thinkin im loosin my mind for tellin ya to run it so I cant say what you should do. I can tell you what I would do and that would be to run it without lookin back but thats what I would do and I cant be held responsible for anything that may happen to you if you decide to do what i do. If that makes any sense. Sooo the choice is yours young Skywalker, choose wisely lol
Cowboy Steve
Old Jun 29, 2007 | 09:46 PM
  #43
tjbeggs's Avatar
tjbeggs
WTF?/?/?/?
Cowboy Steve
Ok way back when we first started this discussion the assumption was that that cut was 1/4 inch deep. that is unacceptable I don't care if it is 1 inch thick. But now that we have verified that the cut is only 1/8 inch deep it is acceptable. See what I am saying there Cowboy. Don't get your chaps all in a bunch! it hurts too much!
Old Jun 29, 2007 | 10:19 PM
  #44
powerstroked162
HAHAHAHAHA, thats a first for the "Dont get your chaps all in a bunch" lol, thats original for sure!
Cowboy Steve
Old Jun 30, 2007 | 05:24 AM
  #45
Cuda_jim's Avatar
Cuda_jim
Cowboy Steve
I'd like to see that. I have ruined a few tires in my day and have never seen a sidewall that thick, especially where his tire is cut. Hell, I can jamb a pocket knife through most sidewalls, that ain't going to happen if it's and inch thick!
Found this on the 'net.
<TABLE cellSpacing=2 cellPadding=2 width=500 border=0><TBODY><TR>Tire sidewalls vary in thickness from the shoulder area to the bead area. In the thinnest part, typically in the middle to upper area, most sidewalls are between 6- and 15-mm thick – about 1/4- to 5/8-inch thick. The differences are dependent upon tire application – thinner for ride comfort street tires (S- or T-rated), thicker for off-road light truck tires that require significantly stronger sidewalls.
</TR></TBODY></TABLE>
