turbo heads
Old Jun 27, 2007 | 11:46 AM
littleme13's Avatar
littleme13
turbo heads
what heads have people found to be good to run with a turbo setup
Old Jun 27, 2007 | 08:14 PM
RacinNdrummin's Avatar
RacinNdrummin
All heads, which ones depends on how much power you want and how much you wanna spend.
Old Jun 27, 2007 | 09:39 PM
littleme13's Avatar
littleme13
im lookin for around 650 hp i just wanted to make sure there wasnt any heads to stay away from or if there was any that worked better with a turbo this is pretty much the last thing i need in my setup
Old Jun 27, 2007 | 09:59 PM
RacinNdrummin
Well It all depends on what your running on the engine. You could get 650hp with stock heads if you run 30 psi. The better flowing heads (as well as cam intake etc) will get you to that point with a lot less boost.
Old Jun 27, 2007 | 11:14 PM
LxMan1's Avatar
LxMan1
CNC ported TrickFlow Twisted Wedge heads made 640 RWHP on a 331 single turbo in one of my FFMM magazines with a CompCams 274 cam I believe. This was @ 9psi of boost.
Old Jul 6, 2007 | 08:25 PM
littleme13's Avatar
littleme13
maybe this will help give me sum advice im running low compression setup and letting the turbos build high boost prob round 20 psi so i guess im wondering if theres any that dont do well with high boost
Old Jul 6, 2007 | 08:50 PM
LxMan1's Avatar
LxMan1
If you are running a production 5.0 or 5.8 roller block, anything much over 600hp will split the block in 1/2. 20 it awful high for a turbo when 600+ hp is easily achievable with 9psi.
Old Jul 6, 2007 | 09:04 PM
RacinNdrummin
Well, if he is using stock<i>ish</i> heads, 9 psi wont give him 600 hp, hell need at least 20 to get even close depending on which camshaft he is running. The main factor in running that much boost is the pistons, get some good- Not <i>ok</i>, <b>good</b> pistons. The next thing is the headgaskets, get some good head gaskets and deck and bore the block with studs. The beauty of forced induction is you dont have to have the latest in flow technology heads to get big power, its basically how much your bottom end can take and how good your tune is.
Old Jul 6, 2007 | 09:37 PM
littleme13's Avatar
littleme13
im not going to use a production block my other thread 302 vs 351 has info on that my bottom end will have no expenses spared i know what happens if you try and go cheap but i dont want to spend thousands of dollars on sumthing i dont need or sumthing that isnt gonna last i want high boost to make my power so i can have it when i want it and i can turn it down just to drive around and take it easy on the engine
arnhed
Apr 1, 2016 05:55 PM
mustangsvo85
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
25
Mar 3, 2016 07:08 PM
Matseffie
Australia Chapter
Mar 22, 2014 06:41 AM
EarlT
Feb 25, 2010 08:00 PM
