79 fi50 ground issue?
Old Jun 26, 2007 | 10:14 PM
79f150toy's Avatar
79f150toy
i have a prob with my truck, at first, the left turn signal would not work unless if you hold the lever a certain way, then it quit working all together for both sides. i checked voltage to the flasher, its ok, but checkd the voltage to the light blue wire at the switch connector, nothing. i also have a issue with the parking lights, basically, nothing works except for the headlights and brakelights. no parkin or side markers, no signal at the firewall connection under the hood.the turn singnal switch was replaced about a year ago, and healight swtch is less than a month old. where are all the grounds for the switches? i check and cleand the grounds to the rear lights, but could the front effect the whole system? plus where can i find a new turn signal swtch for a reasonable price? im thinkin the contacts for the signal swtch are screwwy, therfore, may require replacement. i seemed to have all the issues around the same time frame. and all fuses are ok.
Old Jun 26, 2007 | 10:54 PM
Franklin2's Avatar
Franklin2
Take the headlight switch out, but leave it plugged in. Turn the headlights on and see if you have power on the brown wire leaving the switch. The brown wire is the running lights.
Old Jun 28, 2007 | 05:27 PM
79f150toy's Avatar
79f150toy
will do thanks. i do need the wire diagram for the entire lighting system tho...
Old Jun 28, 2007 | 06:39 PM
Mil1ion's Avatar
Mil1ion
Figure #6 this page.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
josiewales
Feb 14, 2015 09:58 PM
whateg01
1997 - 2003 F150
Sep 1, 2014 11:18 PM
Rudog
Nov 15, 2012 12:35 PM
Copedawg
Jul 21, 2011 05:29 PM
TAF
Mar 20, 2008 11:05 AM
