Right Turn flash issue
Old Nov 14, 2012 | 02:11 PM
Rudog's Avatar
Rudog
Ok. Right turn signals on my 1979 f150 are having issues, wont flash with the tail lights on.
I have replaced in order listed, all bulbs and inspected contacts. Turn signal switch as it needed a new cam anyhow so replaced the whole thing. turn signal flasher relay. (this fixed the original problem of right turn signal not working at all). Hazzard flashers always worked and still do. replaced headlight switch. Im down to thinking its in the ignition switch changing the ignition switch. cant figure this one out. With the headlights on and right turn signal on there is nothing on the right side, with the headlights off EVERYTHING WORKS!!!
Can someone rattle my brain please?
Old Nov 14, 2012 | 02:28 PM
fmc400's Avatar
fmc400
MSEE
Welcome to FTE.
This is a classic sign of ground shift due to corroded sockets. Visual inspection means nothing when it comes to electrical. To solve electrical problems, you must use the proper tools, which in this case is a multimeter.
No turn signals with the headlights on means bad sockets up front. No turn signals with the brake lights on means bad sockets in the back. Therefore you must replace all 1157-style sockets on the truck.
The ignition switch is not related. It has nothing to do with the issue you are seeing. You have no reason to believe otherwise.
Old Nov 14, 2012 | 02:35 PM
Rudog's Avatar
Rudog
Thanks a bunch . I will do some further inspections and post what I find.
Old Nov 15, 2012 | 12:03 PM
Rudog's Avatar
Rudog
Thats exactly what it was. Right rear 1157 socket. Thanks a Bunch.
Old Nov 15, 2012 | 12:35 PM
fmc400's Avatar
fmc400
MSEE
No problem, glad to hear you got it worked out.
Cdorich
Jan 3, 2017 10:43 AM
Louie Klouless
Jun 7, 2015 06:08 AM
JJJP
Electrical Systems/Wiring
Dec 17, 2004 02:51 PM
79_effie
Jun 23, 2003 08:16 PM
