292 timing problems
Old Jun 25, 2007 | 09:48 PM
hellbilly1932's Avatar
hellbilly1932
292 timing problems
1959 f100 292, trying to set timing, having problems. I have my timing light lead hooked to the #1 plug wire and the vacuum advance line pulled from the distributor.
With the engine running the 4* BTDC mark is way too far away from the timing pointer on the engine. Lets say the pointer on the engine is at 11 o'clock, well the mark on the balancer is at around 2 o'clock.
Is it possible the chain jumped a tooth? The truck was still running and driveable but it had started to pop and backfire through the carb so I decided to check the timing and thats when I discovered this.
Is it possible the damper is on wrong? or its the wrong damper?
Do I need to replace my chain?
Old Jun 26, 2007 | 08:26 AM
juterbock's Avatar
juterbock
First check and see if the damper has slipped, if it has you need a new damper. Try turning the pulley and if the crank doesn't turn you need a new damper.
Old Jun 26, 2007 | 10:56 AM
46yblock's Avatar
46yblock
Have you tried turning the distributor to advance the timing to 4 degrees? It may just need adjusting. Rotate dizzy clockwise to advance. Check point gap and adjust if necessary before setting timing.
Old Jun 26, 2007 | 03:11 PM
hellbilly1932
elec ignition
forgot to mention the truck has electronic ignition.
tried adjusting the timing and there is not that much adjustment there.
Old Jun 26, 2007 | 07:42 PM
46yblock's Avatar
46yblock
Then it is back to Juterbox's shifted balancer, your thought regarding timing chain, or the distributor rotor wasnt pointing to number 1 cylinder when it was installed. No other options come to mind.
Old Jun 30, 2007 | 09:27 PM
hellbilly1932
it was a stretched chain. Now im having a time getting the balancer off
Old Jun 30, 2007 | 09:43 PM
46yblock's Avatar
46yblock
Use a ballancer puller. Seems like I have also used a steering wheel puller. I have to pull a balancer myself, and will let you know how the steering wheel unit works out.
Old Jun 30, 2007 | 09:45 PM
hellbilly1932
i have a puller, having trouble getting the bolt out of the crank, is it reverse thread?
Old Jun 30, 2007 | 09:47 PM
46yblock's Avatar
46yblock
No, it is not reverse thread. Is the motor turning before you get the bolt to break loose?
Old Jun 30, 2007 | 09:49 PM
hellbilly1932
yep. that and I wasn't sure if I was turning it the right way.
Old Jun 30, 2007 | 09:56 PM
46yblock's Avatar
46yblock
Maybe there is room for an impact wrench. If I remember right, the last time I broke loose balancer bolt with motor installed I jammed a wooden handle between the pulley and belt, and slowly torqued the bolt loose.
Old Jun 30, 2007 | 11:14 PM
hellbilly1932
ok i got the balancer and timing cover off. I guess I need a gear puller for the crank gear. Oh well it will have to wait for the morning when I can get to the parts store. I have the gears all lined up and ready to take off all I need is the puller
Old Jul 1, 2007 | 12:26 AM
46yblock's Avatar
46yblock
Good. Timing marks should both be at three o'clock with 12 pins between them.
Old Jul 1, 2007 | 12:35 AM
hellbilly1932
done and done. Thanks for all the help.
deputydog03
Modular V8 (4.6L, 5.4L)
32
Apr 9, 2016 12:06 AM
46fordtruck
2004 - 2008 F150
Sep 20, 2014 02:32 PM
deputydog03
1997 - 2003 F150
Dec 11, 2013 01:45 PM
apb
Oct 15, 2009 09:36 PM
TerryM
Sep 30, 2007 08:49 PM
