7.5L timing
Old Oct 15, 2009 | 06:04 PM
apb's Avatar
apb
7.5L timing
I really hate to ask this but where are the timing marks and pointer on a 7.5L? The manual suggests passenger side of engine above crank pulley at about 10 o'clock but I can't see anything there and I can't find any marks on the pulley or damper.
The truck is a '95 7.5 I think it is >8800 GVW with automatic.
Thanks
Old Oct 15, 2009 | 09:20 PM
forddude95's Avatar
forddude95
The timing marks should be on the damper. Hard to see if its dirty or still has paint on
it, had to take a wire brush to mine. The pointer should be right where the manual said unless it has broken off, very thin piece of metal.
Old Oct 15, 2009 | 09:36 PM
apb's Avatar
apb
Thanks,
I had more rust on the damper than I thought. A wire brush did the trick, and the pointer did not stick out as far as I expected it to.
TX460Bronco
May 1, 2013 10:54 PM
trotsky13
28
Nov 29, 2009 07:04 PM
ErrorS
1978 - 1996 Big Bronco
Oct 28, 2009 03:14 AM
jblueep
13
Jan 22, 2007 04:41 PM
MRish6
Feb 11, 2005 06:48 AM
