Sponsored by: Real Truck
Sounds like a school bus
Old Jun 24, 2007 | 10:05 PM
Headviking's Avatar
Headviking
My 07 diesel sometimes sounds like a school bus. You know the extra high pitch whining sound. It sounds like a school bus. This only happens when it is a vary hot day and the truck has warmed up and hand had a good run. I also experiance a bit turbo lag, about 4-6 seconds. If I turn off the truck for about 5-15 minutes the symtoms go away and then sometimes will come back vary soon or not at all. I spoke to the dealer about this and had the truck with me at the time of this problem. He did not have a diesel mech. available at the time to test drive my truck. He did mention that it sounds like an EGR valve sticking. He booked me in on Thursday and kept my ride till Friday afternoon. Nothing. The mech. found nothing, he test drove the truck for about 20 minutes and could not duplicate the same. No error codes showed up either. Here it's Sunday and it happened again. The dealer told me that if they can't find the problem they can't fix it. Any idea's to what is causing this.
Headviking
Old Jun 25, 2007 | 01:16 AM
riggz's Avatar
riggz
when do you hear the noise? on acceleration? decel? idle?
Old Jun 25, 2007 | 01:37 AM
blackhat620's Avatar
blackhat620
Headviking,
Sounds like the "Visconic" PCM controlled fan engaging to cool the radiator. The PCM controls the amount of lock up of the fan based on ambient temp, engine coolant & oil temp, engine load etc.
Old Jun 25, 2007 | 09:56 AM
2006HarleyF250's Avatar
2006HarleyF250
All diesel engines make that sound when the fan kicks in to cool the radiator. If you haven't owned or driven a diesel before, you might think your truck is going to fall apart but it won't. That is just what happens when your truck gets hot! It will be okay.
Old Jun 25, 2007 | 02:14 PM
04superduty's Avatar
04superduty
it sounds like a school bus because it is the same engine. the VT 365 is in almost all the new international school buses. there is a grade school down the street from me so i get to hear them alot.
Old Jun 25, 2007 | 11:05 PM
Headviking's Avatar
Headviking
I dropped in at my local dealer today while I was experiancing the turbo lag and the loud whining sound. The mechanic test drove my truck and said that my turbo was not kicking in as fast as it should. He is going to remove the turbo to take a look at the fins to make sure thay are not sticking in the open or closed possision. He will also take out the and checking the EGR valve to see if it is not coated with carbon. He did make mention of the load rad fan and will be checking into that as well. I will be dropping my ride in on Thursday morning for the day and maybe two. Will keep you posted on the results.
Old Jul 4, 2007 | 05:19 PM
Headviking's Avatar
Headviking
Well I picked up my ride on Friday. The dealer replaced my EGR valve (turbo lag) and my cooling fan clutch assembly (Whining sound). It drives like the day I picked it up new.
Headviking
1bigjoe
27
Aug 15, 2017 06:15 AM
Orpackrat
General Diesel Discussion
17
May 17, 2009 03:00 PM
01FordCrew
Apr 3, 2008 11:42 PM
ernesteugene
Aug 30, 2007 03:28 PM
bobj49f2
26
Jan 6, 2006 11:58 AM
